Question about Apple iPhone 4 Black Smartphone
Pairing code for iphone 4 - Apple iPhone 4 Black Smartphone
    New Friend:
  • 57 Answers
Paring code should be a same number with your device . so if you put down 123 for one device then 123 will be the code for the other device..
Posted on Nov 03, 2011
6ya staff
SOURCE:
Pairing to i Phone
Reboot iPhone. Go to Settings, Bluetooth, switch off and then back on. Power up headphones. Press the button on the headphones that you need to press to send the signal to the iPhone (this is the part that most people don't get). When found, click Pair on the iPhone. If it asks for a code the default is 4 zeros '0000'.
for instructions Google
make model manual
or
make model instructions
Jul 25, 2016 | Radio Communications
Connect iphone 4 to Macbook via Bluetooth
Are you running Mavericks on MBP and IOS 7.1 on Iphone 4?
Oct 07, 2014 | Apple MacBook Pro Laptop Computer with...
Why won't my new iphone 5s pair with my Cardo scala G9x? My iphone 4 pairs very easily.
believe that it is because the 5s is digital and the 4 is analog--we install blue tooth systems in cars and had to replace most of them because of the release of the 5s--older blue tooth system are analog so are not compatible with the 5s--as probably is what is your problem
Jul 27, 2014 | Apple iPhone Smartphone
I do not have the manual and do not know how to connect my iphone 4 to a Wansun Bluetooth hands free speakerphone visor kit.
Standard Bluetooth speakers you just hold the power button on til the blue light flashes.
Once that's accomplished, it's in pairing mode.
Go into the setting in your iphone and turn on bluetooth. It should then find all items waiting to be paired.
Click on the speaker, if it prompts you for a code it's standard four zero's 0000 and it should connect and work.
Apr 15, 2014 | Apple iPhone 4 Black Smartphone
Cannot pair my iphone 4 with jabra sps5050
The reason is you need a four digit code in order to pair your Bluetooth to your phone. Also, your phone has to be 'Able to be found', ie, set your Bluetooth settings on your phone, so that the phone is in 'Discoverable Mode' and ensure the Bluetooth setting itself is also turned on.
Once your phone is Bluetooth discoverable, try and pair the devices again. Your phone will find your headset and ask if you would like to pair the two devices. Obviously, select Yes/Pair and it will then require a 4 digit code for authentication. With Jabra the code is always "0000" (4 zero's). Once you enter the 4 zero's, the two units will then pair successfully.
Let me know if you require further assistance.
Feb 18, 2011 | Jabra SP5050 Bluetooth Headset
Bluetooth keeps aking for a pairing code. each 4 digit one I tried fails..says:cannot pair with ford audio..using n96 and iphone 4 both fail to pair
Did you try just pressing enter (no code)? If not, try "0000" I found something here: http://fordfcsd.wunderman.be/UK/Audio%20-%20Multimedia%20-%20Navigation/Bluetooth%20%26%20Voice%20control/bluetooth%20%26%20voice%20control%20%28cg3504en%29%2001-2006.pdf which indicates "0000" is the code, but enter should do it
Feb 04, 2011 | 2008 Ford Focus
My Jawbone headset will not pair with the iphone 3g, even after going to settings-general-bluetooth. The iphone keeps serching for a device but cannot find it.
1. Settings
2. Bluetooth
3. Turn Bluetooth ON
4. Make sure your Jawbone is OFF
5. Press TOP Of Jawbone & MIDDLE of Jawbone TOGETHER Until It Flashes Red & White
6. JAWBONE Will Come Up On The iPhone
7. Pir The Device With iPhone
8. Enter Four Digit Code
9. 0000
10 HEY PRESTO....YOUR PAIRED!!!!
Thanks to Sally Jo for this tip!
Dec 31, 2009 | Apple iPhone 3G
Apple iPhone 4 Black Smartphone Logo
Top Apple Cell Phones Experts
Ekse
jacobcheatha
Level 1 Expert
Marvin
Marvin
Are you an Apple Cell Phone Expert? Answer questions, earn points and help others
