SOURCE: setting of a microwave
You can download the owner's manual If you will copy and pastew the entire URL into your browser's address bar:
http://org.downloadcenter.samsung.com/downloadfile/ContentsFile.aspx?CDSite=us&CttFileID=29957&CDCttType=UM&ModelType=C&ModelName=MT1066SB&VPath=UM/200303/20030318134829578_DE68-02235A.pdf
This will be the perfect solution to your problem.
We're happy to help and we appreciate your thoughtful rating of our answer.
SOURCE: cooking temp to bake cake inn convection mode samsung model
Hi I guess you are cooking usng the combination setting? if so The cake will be hard due to increased microwave energy, I would suggest reducing the microwave energy on the Samsung unit when using the combination setting.
Hope this helps
SOURCE: I have GE model DE68
From your the description everything works but it won't heat. The problem is most likely the magnetron that heats the food is defective, or the least likely the high voltage transformer that drives the magnetron, either way the cost of repair will exceed a new microwave oven.
SOURCE: i have samsung CE103VD microwave.could
I too have the same problem i try to bake cake and it turns to become biscuit or it dosnt cook in the centre
