I am the one here who first posted about taking the front keyboard out; if you replaced the caps in the DM unit and or pico fuses and still have the 'blinking green light of death" consider sending the board unit to PTS electronics.
You can get a quote from them for the repair and they have a 800 number; if you tried the usual things and it does not work go that way. Even with the factory service manual and schematics you will find it nearly impossible with the Unit in the set to take voltages and troubleshoot it.
DM unit in correctly working set should cause set to have blinking power light for about 70 seconds and then go out--it is DM booting up---if it does not stop blinking either a problem with DM or connections where it plugs into main board.
Let me know if you have questions or need help, I am here to help
SD TECH
