Generac 100 Amp 120/240-Volt Transfer Switch #RTSN100A3 Logo
A
Anonymous Posted on Oct 14, 2011
Bought a new Generac XG8000E generator and output is 92 volts instead of 120 volts. Should unit be returned or can a simple adjustment fix problem. How do I Adjust unit?
DocZachary
Level 3:
Master:
  • Master 533 Answers
  • Posted on Feb 13, 2018
DocZachary
Master
Level 3:
Master:
Answers
533
Questions
Helped
167762
Points
2496
From what I can see on the Generac website, there are no user adjustments on the unit. I suggest taking it back to where you purchased it and have them check it out. If it indeed is putting out 92V vs 120V, have them replace it but check it prior to leaving the store.
Good luck,
Semper Fi,
Z
Joseph Mueller
Level 2:
Mentor:
An expert who has written 3 tips or uploaded 2 video tips.
  • Expert 346 Answers
Joseph Mueller
Expert
Level 2:
Mentor:
Answers
346
Questions
Helped
171865
Points
784
The manuals below will help with this question. PG 122 of the service manual will start the flow charts for this problem. www.arcolawn.com is who I use for parts. They ship fast and are super helpful. Material Number Manual (PDF) 0H4099 EV C/PNL 410 XG PORTABLE 6.5KW 0H5145 WD SD 8.0KW XG ES 0J1587A EV XG8000ES 49ST 0J2873 EV XG8E 410CC 0J4651 MANUAL LOWES XG8000E 0J3335A WARRANTY STATEMENT EMSN E1 P3
5 Related Answers
joboo1
Jim London
  • 257 Answers
  • Posted on Feb 08, 2009
SOURCE: Generator output
Hi, You don't say whether this is under load or not but if not is within the acceptable range, which is +/- 10% . Generally speaking, voltage on a generator is not the issue but the load which it will carry, hence their wattage ratings. Measure your household voltage and you will see that it varies from day to day but usually stays within the limits and your electrical panel is rated in amperage. Hope this answers your question!
mamicheddy
mamicheddy
  • 79 Answers
  • Posted on May 12, 2009
SOURCE: No voltage output
It is possible that your voltage regulator is shot but before purchasing the volt regulator try flashing the fields first and make sure the brushes and rings are clean.
Anonymous
  • Posted on Jan 23, 2010
SOURCE: When utility power goes out, the transfer switch doesn't transfer
Call an electrician.
Anonymous
  • 142 Answers
  • Posted on Jun 04, 2010
SOURCE: My Generac Primepact 50 RV generator has no AC output.
Check the exciting field wires and fuses.
Anonymous
  • 10 Answers
  • Posted on Aug 10, 2010
SOURCE: my generator is not putting
Most low voltage conditions on generators are simply due to a low engine rpm. Most modern generators are 2- pole windings. So your engine rpm should theoretically run @ 3600 rpm. which will produce 120/240 volts @ 60 HZ. In actuality You want to set your rpm's @ Approx. 3720rpm no load. About 62.5 Hz. Without getting to technical this will give you your desired 120/240 volts loaded. Hope this helps.
Generac XG8000E only producing 67volts on each leg.
Beware of an adjustment complexity with an new kind of poweroutlet automatic voltage regulator avr , have you measured the generator UNLOADED for 230 volts ?
because it can be normal that 67 volts output changed when you connect an paint heat gun i was surprised a few weeks ago that i get an GENMAC 8000 that is a look a like generator coming from china build . first i was measuring some of the same output AC instead of 230volts.
My generac rv generator runs bu no voltage output.
Try putting 12 volts across the commutator at the brushes. Ust a low current battery nor a car storage battery.
Good luck,
Marty
Low voltage out 79.2 volts
Randy, connect up your volt meter and try manually reving up the engine. Even a few hundred RPM can make a big difference in the generator output.
If that resolves the problem, then you need to adjust the high speed settings on the motor.
1helpful
I purchased a generac 22 kw 3 phase 120/240 volt generator. I was surprised to find that it had a wild leg. Can i change the leads on the stator output to eliminate the high leg and get straight 120/208...
This unit is wired 120-240V 3 phase Delta. if you are using on it 120/208V 3 phase application it will need to be re-tapped. If you are using it in a home 120-240V single phase it will need re-tapping, Do NOT just use 2 legs, as this will cause rotor imbalance and wear out the rotor bearings, and odd ball currents to flow. If there are 12 leads coming off the stator it can be reconnected. If not you are stuck with it, except by using a transformer
Generator problems
yes
but battery charge voltage has to be 14.5-14.8 volts to charge a battery
batteries are known to be 12 volts but in fact at 2.2 volts a cell they are 13.2 volts capacity so 13 volts will not charge a battery
Voltage problem with Generac XG8000E Portable Generator
The manuals below will help with this question. PG 122 of the service manual will start the flow charts for this problem. www.arcolawn.com is who I use for parts. They ship fast and are super helpful. Material Number Manual (PDF) 0H4099 EV C/PNL 410 XG PORTABLE 6.5KW0H5145 WD SD 8.0KW XG ES 0J1587A EV XG8000ES 49ST 0J2873 EV XG8E 410CC 0J4651 MANUAL LOWES XG8000E 0J3335A WARRANTY STATEMENT EMSN E1 P3
Low voltage output on xg8000e portable generac generator voltage is only 103/207
You may find the following documents helpful for troubleshooting and parts. I use www.arcolawn.com for parts but any reseller can assist you. Material Number Manual (PDF) 0H4099 EV C/PNL 410 XG PORTABLE 6.5KW 0H5145 WD SD 8.0KW XG ES 0J1587A EV XG8000ES 49ST 0J2873 EV XG8E 410CC 0J4651 MANUAL LOWES XG8000E 0J3335A WARRANTY STATEMENT EMSN E1 P3
How do you adjust voltage output on new Generac XG8000E generator? Current output 92 volts. Suspect rpm's need to be increased.
You may find the following documents helpful for troubleshooting and parts. I use www.arcolawn.com for parts but any reseller can assist you. This model does have an adjustment on the AVR behind the main panel but please review the below manuals before adjusting. Material Number Manual (PDF) 0H4099 EV C/PNL 410 XG PORTABLE 6.5KW 0H5145 WD SD 8.0KW XG ES 0J1587A EV XG8000ES 49ST 0J2873 EV XG8E 410CC 0J4651 MANUAL LOWES XG8000E 0J3335A WARRANTY STATEMENT EMSN E1 P3
Top Generac Electrical Supplies Experts
vince
Paul Bade
Are you a Generac Electrical Supply Expert? Answer questions, earn points and help others
