SOURCE: nikon d40
I had exactly the same problem, i tried everything,battery out, sd card out , lens off etc...nothing worked.Completely by chance and irritation i repeatedly pressed the shutter butten over and over
( without the lens attached ) till it didn't react at all.On my LCD i got a normal menu so i put the lens on and bingo it was fixed, still works fine.I think maybe the shutter was out of alignment.
Hope this works for you.
Olly
SOURCE: Error. Press shuter release button again
I was taking pictures, then when I pressed the shutter release button, it took a long time. Then the error message came up. I tried pressing the shutter release button again, nothing happens. Still the error message. Please help me
SOURCE: Nikon d40x shutter stuck
The manual (pg 112) simply, and unfortunately, states this message "Press shutter release button again. If error persists, consult with Nikon-authorized service representative".
Some questions that might help: have you had the camera in some extreme conditions, damp, sand, etc. Clean the shutter button really well. Maybe use a small air blower and clean in the shutter release creases.
In the end, if the error continues, it will need to be serviced.
SOURCE: nikon d40x error saying
check the lence is working properly then the focusin option is auto or manual the auto focus 18-55 lence is properly fixed on mount or not
