Konica Minolta DiMAGE Z6 Digital Camera Logo
Anonymous Posted on Oct 13, 2011
The Konica Minolta DiMAGE Z6 will not read the 8 GB card
Level 3:
One Above All:
The expert with highest point at the last day of the past 12 weeks.
Top Expert:
  • Konica Minolta Master 102,366 Answers
  • Posted on Oct 13, 2011
Level 3:
One Above All:
Top Expert:
Answers
102366
Questions
0
Helped
10442618
Points
622693
The Z6 uses MMC and SD cards. If you look carefully at your 8GB card, you'll see that it's an SDHC card. While it fits into the slot, it is electronically incompatible and will not work. The Z6 is limited to cards 2GB and smaller.
2helpful
Is there an up-date which will allow dimage Z6 to use a 4 GB storage card please. My camaera will only recognise up to 2GB SD card.
Sorry, no. SD cards max out at 2GB. Larger SDHC cards are electronically incompatible and will only work in devices specifically designed to accept them. It's a hardware incompatibility and no amount of firmware changes will make a SD device accept SDHC cards.
8helpful
8 Gb SD card not recognized by Minolta DiMage Z6 digital camera. What is maximum size SD card this camera can address?
The Z6 works with MMC and SD cards. Your 8GB card is actually an SDHC card. While SDHC cards will fit into SD slots, they are electronically incompatible and will not work. You need to use MMC or SD cards, 2GB and smaller.
3helpful
Konica minolta dimage z6 card locked. how do i unlock it
Look at your memory card. SD cards have a slide switch along one edge. The position farthest from the contacts locks the card, protecting it from writes. The position nearest the contacts unlocks the card. If the switch is already in the proper position, slide it fully the other way and then back again.
If that doesn't work, try another card.
4helpful
2answers
Need battery door part for Konica Minolta Dimage Z6 camera
e bahttp://cgi.ebay.com/NEW-KONICA-MINOLTA-Z6-BATTERY-COVER-SILVER-OR-BLACK_W0QQitemZ320433162573QQcmdZViewItemQQptZDigital_Camera_Accessories?hash=item4a9b4e094dy -24.99 at this site-
2answers
I was told last year when I researched it from the website, only a 2 GB card could be used.
Top Konica Minolta Cameras Experts
ZJ Limited
ZJ Limited
Grand Canyon Tech
Grand Canyon Tech
Are you a Konica Minolta Camera Expert? Answer questions, earn points and help others
