To remove back leg: pull off round end caps where leg connects to back (pressure fit). Then remove black stickers covering screw holes at base of leg. Under stickers are 4 screws - remove and lift off leg assembly.
Remove back cover: remove 7 black screws from back (one hiding under warranty sticker). Lift back from bottom edge (pressure connections on top edge). Back cover will catch on cd/dvd tray door - bend slightly to get around.
Under back cover is metal cover. Remove screws from around edge holding back cover on (note that most screws you will see in pairs - only remove the one holding the metal cover, not the one holding the chassis). Lift off metal cover.
You should now see hdd. One screw holding in position - remove screw, slide out hdd (it will have a metal frame around it). HDD is a 2.5" laptop style.
Swap out hdd from its frame, then re-assemble.
http://www.ehow.com/video_4978913_install-internal-hard-drive.html
utube video install a second ide hard drive
http://www.fonerbooks.com/laptop_1.htm
laptop hard drive
hope this helps
