Lands Phones Logo
Posted on Sep 22, 2008
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
The backlight on my sidekick lx went out - Lands Phones
Anonymous
Level 1:
  • Contributor 2 Answers
  • Posted on Sep 22, 2008
Anonymous
Contributor
Level 1:
Answers
Questions
Helped
886
Points
5
If still under warranty youshould take it back to t mobile as a factory defect and get them to fix it as far as i know it sounds like a sensor or such that went out but they wont take it to repair if it is from water damage
Anonymous
Level 3:
President:
  • Master 625 Answers
  • Posted on Jan 21, 2010
Anonymous
Master
Level 3:
President:
Answers
625
Questions
0
Helped
344720
Points
1259
If the backlight on your sidekick lx is bad then you probably need to replace it.
Check out the following guide on how to replace the LCD screen on yousidekick LX. There are also links to buy a new sidekick lx lcd screen.
Sidekick LX LCD SCreen Replacement Guide
1helpful
Well I need my Sidekick LX to be unlocked to my local network (Digicel Jamaica) and I wanted to get the code as fast as possible I really need help with this
You can unlock the Sidekick LX from Jamica Network digicel using the Unlock code ,you can get the Unlock code within 0 to 5 Hours(approx) you can get the code at reasonable cost here Simpleunlocking.com and Unlock it ,then you can use it with any GSM Network Sim card....Follow the instructions below and Unlock it step by step...
Sidekick LX Unlocking InstructionsWarning : Do not enter any wrong unlock codes on your Sidekick LX mobile phones. If you enter over a certain amount of wrong unlock codes on your Sidekick LX mobile phone, your phone may get hard locked and sometimes become unusable.
1. Switch ON your Sidekick LX with a Not ACCEPTED SIM Card.
2. If your Sidekick LX asks for a PIN code, then enter your SIM card PIN and press OK.
3. Sidekick LX will ask to enter an "unlock code".
4. Enter Unlock Code we send to you.
5. Your Sidekick LX is now unlocked.
*NOT ACCEPTED : We mean, to use a Sim card from a network other than the network your Sidekick LX is locked to.
My sidekick lx 2009 didnt ask to enter code, plz help me thanks u
It says just Network lock only,You need to enter the Code if it locked Network mean.You can get the Unlock code at here
http://www.superunlockcodes.com/sidekick-lx-2009/rs12wp9/ and Unlock it,get the Unlocking Instructions below to unlock it step by step.
Sidekick LX 2009 Unlocking InstructionsWarning : Do not enter any wrong unlock codes on your Sidekick LX 2009 mobile phones. If you enter over a certain amount of wrong unlock codes on your Sidekick LX 2009 mobile phone, your phone may get hard locked and sometimes become unusable.
1. Switch ON your Sidekick LX 2009 with a Not ACCEPTED SIM Card.
2. If your Sidekick LX 2009 asks for a PIN code, then enter your SIM card PIN and press OK.
3. Sidekick LX 2009 will ask to enter an "unlock code".
5. Your Sidekick LX 2009 is now unlocked.
*NOT ACCEPTED : We mean, to use a Sim card from a network other than the network your Sidekick LX 2009 is locked to.
Each Sidekick LX 2009 mobile phone has an unique unlock code. You can buy the unique unlock code for your Sidekick LX 2009 mobile phone using the form above.
Sidekick lx screen went blank isnt working..
You can try to reseat the lcd cable and make sure it is tight. It that fails then you will need to replace the LCD screen
Here are instructions for replacing the Sidekick LX screen: How to replace the Sidekick LX LCD Screen
and here is a link to the LCD screen son ebay.
Sidekick LX LCD Screens
My sidekick 3's backlight wont turn on
Here is a guide for it Sidekick 3 LCD Flip Screen Replacement
and here is a link to the screens
Buy a replacement Sidekick 3 LCD screen.
Sidekick 3 backlighting won't work
If the backlight is burned out then you will need to replace the LCD screen. It is fairly easy to do and runs about 30 dollars from ebay.
Sidekick 3 LCD Screen Replacement
and here is a link to buy the LCD screens
New Sidekick 3 LCD Screens for Sale
Sidkick lx lcd backlight malfunction
how to connect my datacable to my sidekick mobile? it when i connect it shows malfunctioned.
1helpful
No display light
It is possible that the backlight on your LCD is burned out. If you have a friend with a Sidekick LX, see if you can swap the lcd screens quickly. This will let you determine if it is the phone or the LCD screen
Here is a link to show you how to remove and or replace the Sidekick LX Screen
Sidekick LX LCD Screen Replacement
7helpful
2answers
Sidekick lx screen
un screw the screen blow at the metal ends inside the phone and the lcd and screw it back on and do that until it works
Sidekick lx
To fix your sidekick lx screen follow this guide I wrote.
How to replace Sidekick LX LCD Screen
A new lcd screens runs about 100 dollars:
You can check them out here:
I hope that helps you all
7answers
Backlight on sidekick 3
Because your screen is broken and that can only be fixed if you have it replaced.
Top Lands Phones Experts
k24674
Are you a Lands Phone Expert? Answer questions, earn points and help others
