SanDisk 2GB microSD Memory Card Logo
Anonymous Posted on Oct 12, 2011
My 2gb sandisk micro SD card reduce the size after formatting
Anonymous
Level 2:
  • Expert 149 Answers
  • Posted on Oct 12, 2011
Anonymous
Expert
Level 2:
Answers
149
Questions
0
Helped
92884
Points
293
Possible micro SD bad sectors. To check your micro SD bad sector or not, you use the HD Tune software. To restore the capacity micro SD, which is done is Low Level Format. You can use the software HDD Low Level Format Tool.
How to use HD Tune and HDD Low Level Format, you can see here
Transcend Repair Bad sectors
How to repair micro SD, you can see in here
MMC Repair Without Losing Data Video 2
1helpful
I forget password of sandisk 2gb micro sd memory card
you can unlock your sd card by formatting*.
formatting memory card will delete all datas
formatting method*
use a softtwaer phone for formatting.. (example nokia 6120c, 5800etc )
insert your sd card into the softwaer phone.. select SETTINGS > DATA MGR > MEMORY > OPTIONS > FORMAT MEMORY CARD
I added a 2gb mirco SD card to my Sansa e270 6.0gb player, but the memory is still only showing 10mb of the original 6.0 gb available for use. How do I get the Sansa to recognize and use the 2 gb mirco SD...
Hi,when you purchase a new micro SD card before use, youwill need to format the memory card so that you will be able to know the actual size of the Micro SD card by checking the details after formatting it.
After formatting the micro SD card and checking the details, if you still do not see the accurate size which is about 1.88mb or the about, that means the micro SD card you bought needs to be replaced. Not a good one.
Have a nice day.
2GB Micro SD needs format code that I never gave it
You can format your micro-SD Card using a software which you can download by clicking this link. I uploaded it to my FTP site for you and it will be there for a limited time. Download that file and save it to your PC. Then unzip that ".zip" file.
If you format micro SD card connecting it to your PC via USB port, it may not ask for password. (I think your phone asks password to format.)
To format your micro-sd card:
- First plug in your micro-sd card into you PC.
- Run the downloaded "HPUSBFW_2.2.3_MASTER.exe" file.
- In the program menu window, select the device (your memory card).
- Select FAT32 as file system,
- Confirm that all the format options unchecked. (Uncheck the quick format option)
- And click the "Start" button to begin formatting.
Hope this helps you.
If you would like to vote for the answer, this will help the others to see the similar problems solved and also will be a satisfaction factor for me to continue helping you.
All the best.
2answers
Tried to download software for r4 micro sd card 4gb sh but does'nt work.comes on the ds loading ,works fine with 2gb sd card,any ideas? thank's colin
Hey there Colin,
The original R4 card only works with Micro-SD cards up to 2GB in size. To use Micro-SD cards up to 32GB, you need to buy the newer R4 SDHC card or a Nintendo DSi comaptible card. Check out R4 Cards / R4 DS Cards from DSCardWorld.com or NDS-Gear.com (NDS-Gear is probably better if you live in Europe or Canada as their shipping's slightly better internationally).
Can only put 164 songs on 2gb micro sd card
format the card first and check if its 2 gb still. now compress your songs with the software mp3toringtonegold. now you can load more than 1000 songs depending upon your compressions. but compression can reduce the quality of the sound.
Trouble in formatting my SD micro sd for my lg chocolate cellpfon
use some other card reader for the purpose and format it from there.
1helpful
2gb micro sd From Sandisk printer won't read.
From what info I have gathered is that my card reader on my printer is old and will not read that big of card. so off to the computer store to buy a new card reader.
Sd card format/volume problem
Its better to avoid using disk management to format to format the card.
Use this formatter to format(usually the memory cards are factory formatted in the FAT or FAT 3).
http://panasonic.jp/support/audio/sd/download/ftp/sdfv2003.exe
Or
ftp://ftp.vaio-link.com/pub/memstick/drivers/MSFMTINST250.exe
Usually its better to format the card using the phone only.
Good Luck.
Live, Love, Laugh.
Top SanDisk Electronics - Others Experts
k24674
Grand Canyon Tech
Grand Canyon Tech
Sean Wright
Sean Wright
Are you a SanDisk Electronics - Other Expert? Answer questions, earn points and help others
