Question about APC BE500U ES 500 USB BACK-UPS 500VA/300W 120V (NEWITEM13161417) UPS System
Apc es 500 no power - APC BE500U ES 500 USB BACK-UPS 500VA/300W 120V (NEWITEM13161417) UPS System
6ya staff
SOURCE:
Anonymous
  • 33 Answers
SOURCE: UPS Switching off while working
Hi kumaraswamy5,
it seems that either the UPS is connected to an outled which isn't grounded properly or the battery inside of the UPS needs a replacement.
On APC's website you can find the compatible batteries for your device and where to order them. Replacing the batteries is very easy so don't be afraid of that!
Greetings from Germany,
noris017
PS: Please don't forget to rate this advice after you've tested it out! Thanks in advance and have a nice day!
Posted on Feb 25, 2009
Mike2304
  • 28 Answers
SOURCE: green light flashes with a constant buzzing sound
It sounds like you need a new battery. If the APC is more than 3 years old, that is likely the problem. You can get a new battery from http://www.batteryinternational.com/apc-backups-es-be500u-ups-battery-ups-batteries-f2.html
Posted on Jun 23, 2009
Geekman
Chris Hingee
  • 32281 Answers
SOURCE: hi in my apc es 500 the amber and green light is
Batteries in the UPS typically last 3 to 5 years and it depends upon several factors. including the number of times the unit must go on battery power and environmental conditions. There are usually several batteries in the UPS and while the battery voltage may show 13 volts, this may only be a float charge/voltage and a true indication of the battery voltage and condition requires the batteries to be tested under a load. There maybe one battery in a set of batteries that is faulty and causes the whole battery system to fail and indicate a battery fault.
These lower powered and cheaper type UPS are switch over types, when the mains supply fail, the UPS switches over to the battery and inverter in milli-seconds which then supplies mains power. A faulty inverter circuit and or flat batteries won’t deliver standby power when the mains supply fails.
Posted on Nov 12, 2009
Anonymous
  • 19 Answers
SOURCE: APC Back-UPS ES 500: green light flashes&continuous warning tone
On this unit, the likely culprit is the battery and that it needs to be replaced.
With that, you may want to think about the pros and cons of replacement versus buying an entirely new unit.
This unit is a relatively low end ups and the surge supression uses MOVs that wear out with repeated absorption of energetic spikes. That's why the better (and higher cost) UPSs and surge suppressors don't use them. They're not really that good anyway due to their relatively high transient impedance. The better equipment uses a "transorb" -- basically a back-to-back high voltage zener diode optimized for low breakover impedance and high instantaneous power capability. Unless the transient exceeds the design parameters of the circuit, these do not wear out and do not degrade. That being said, I will assume that you would likely replace this unit with a similar one.
The flashing may not be the battery at all and may be the charging circuitry, thus your new battery may not live very long (half the life that you would expect.
Many batteries out there are refurbs and have issues as all used parts do.
If you contact APC, they will likely give you a 35% discount on purchasing a new product.
The difference in price in the battery replacement vs. ups replacement at this level may only be a few dollars more.
I promise that I am not a UPS salesman, I just deal with many on a daily basis; therefore I am giving my two cents to try to thelp you avoid problems a year from now.
Posted on Dec 30, 2009
Testimonial: "Outstanding answer with right amount of detail. I swapped battery with identical APC UPS that I have and vfd that battery was cause of warning tone."
RAGHU
  • 401 Answers
SOURCE: red light and beeping
change the battery
Posted on Mar 11, 2010
APC BACK- UPS ES 500 IS NOT SWITCHING ON !
Quite likely that the battery has died in it .they do not like being put to bed for extended periods of time .
Aug 31, 2015 | APC Computers & Internet
Apc es 500 making a buzzing sound when plugged in
Sounds like it could be a bad battery connection or the unit is damaged at the internal components level - probably the charging inverter. You can replace your UPS using APC's Trade-UPS Program: http://buy.apc.com/commerce/storefronts/tradeups/tradein.aspx?storefrontcode=apcetu&countrycode=us&languagecode=en&tradeups_id= Make sure to pay attention to the country/region before you start filling out your information -- the link send you to the USA country.
We also sell them -- the direct replacement unit is a BK500BLK.... $116.70 your price not including shipping. We ship anywhere in the USA.
If you need UPS, Surge, or Power Related help contact:
Daniel (daniel@psihq.com) with Power & Systems Innovations 800.260.2259 or go to our website: http://psihq.com/
•• If this helped - click YES :) ••
Jun 05, 2014 | APC BE500U ES 500 USB BACK-UPS 500VA/300W...
My apc back ups es 650 has a continous chirp what doe that mean?
the chirp means a power event has occurred and the unit needs reset to continue operation , power events can be a few things ( to large a current was applied as a load to it , the power stayed off till battery failed and it had to charge it back up when power comes back on )
Apr 29, 2014 | APC BE500U ES 500 USB BACK-UPS 500VA/300W...
APC UPS ES 500 series continuous beep sound and flashing green light
Hi Lasantha,
Check the battery in your UPS - it's most likely going bad and you will need to replace it.
If you need UPS, Surge, or Power Related help contact Daniel @ Power & Systems Innovations 800.260.2259 or go to our website: http://psihq.com/
** If this helped - Give it a Thumbs Up :) **
Dec 03, 2013 | APC BE500U ES 500 USB BACK-UPS 500VA/300W...
APC BACK-UPS ES 500VA fails to provide back up during power failure
Get APC Powerchute Personal Edition for free and run it. If it says your battery isnt charged, check its voltage disconnected. Charge it with a car battery charger and see if its still a good battery. If not , replace it. If the battery is good, then check the charging voltage. Should be about 14 volts. if not, check the small transformer on the main board. Should be 120 in and 17 to 18 out. 4 diodes in a bridge for charge. The input to the transf has small fuse into it alone.
Jan 04, 2013 | APC BE500U ES 500 USB BACK-UPS 500VA/300W...
My Apc Back UPS Es 500 did not charge and then there is power when I turn on the switch. How could I repair this problem?
Good Day! Try changing the battery. please visit apc's service center for battery replacement. it will only take 3-5 working days. once done, your ups will be as good as new.
Nov 09, 2010 | APC BE500U ES 500 USB BACK-UPS 500VA/300W...
Clicking
that's a sure sign that you are in low battery condition, and the inverter is approaching shutdown. You may need to either deep recharge the batteries, with NO load, or replace them completely.
Got Backup?
Feb 10, 2008 | APC BE500U ES 500 USB BACK-UPS 500VA/300W...
APC BE500U ES 500 USB BACK-UPS 500VA/300W 120V (NEWITEM13161417) UPS System Logo
227 people viewed this question
Top APC Computers & Internet Experts
Gruber Power...
Gruber Power...
Shawn DuRee
Are you an APC Computer and Internet Expert? Answer questions, earn points and help others
