SOURCE: Cobra radar detector speaker replacement
I contacted Cobra via internet site and ordered the speaker. However, it has been on order for over 6 weeks and still not here. I would have figured this would be a relatively high failure item and would be stocked. Thanks for the response. ohmhead
SOURCE: speaker replacement
wow everyones google must be broken (i'm just joking). I found this speaker, it looks like the company is located in arizona. I also contacted cobra and left a message. I'll probably go with whatever is cheaper, it will probably be this one.
https://www.litchfieldstation.com/xcart/product.php?printable=Y&productid=999002749&js=n
Looks like all you have to do is desolder the wires and resolder them on the new speaker then plug it in.
I actually had 2 talking radar detectors go bad (esd-9860, esd-9870) so i took them apart, 9870 had a really small zener diode come lose (probably from leaving it in the sun all these years) and the other one has a completely blown speaker (doesn't make a circuit). The good speaker tested 7.7 ohms with my digital meter.
Figured i'd help you guys out
SOURCE: radar detector speaker busted
The best way is to call up cobra or ask them a question through their site.
http://www.cobra.com/index.cfm?fuseaction=support.ask
This will link you to the ask page. Just ask if they will sell you a replacement speaker for the radar detector xrs 747. I just ordered one for a friend and it was $4.32 and $2.50 for shipping.
Customer Service:
[email protected]
1-773-889-3087
SOURCE: ''I have a xrs 9730 radar detector and the speaker quit working''
Most likely the speaker simply blew due to excessive heat. This is a fairly common problem with all makes and models of radar detectors. Contact Cobra. They should either be able to send you a replacement speaker which you can install yourself, or they should issue you a RMA so that you can send in your Cobra for service.
SOURCE: undersatanding the 12 bands of cobra xrs 797
Its all marketing hype. Cobra breaks up the three X, K and Ka bands into sub-bands, and they do the same for the single 904nm laser wavelength. There are no sub-bands for X or K band. In the USA, Ka band radar guns operate on three Ka band frequencies: 33.8, 34.7 nd 35.5 MHz. Cobra also breaks up the single laser band based on the known pulse rates of various laser gun models. Yet in general if you get a laser alert from a nearby cop then likely you have been tagged and will be getting a ticket.
