Question about GE Profile JTP56 Electric Double Oven
GE Profile double Built-In Oven error Code
I am getting an FO error code on my upper oven. What does this mean
  • 7 more comments
  • Anonymous Nov 26, 2008
    Same thing. F0 code and beeping every once in a while.
  • southernoaks Dec 05, 2008
    The FO error code came on today for both my upper and lower ovens. Very odd, because the oven hasn't even been used for several weeks! The clock is working and the clear button removed both FO codes, but the rest of the panel will not work or operate the ovens. Currently, the timer beeper goes off every five minutes and the FO light for the upper oven comes back on -- pushing "clear" stops the beeping and turns the FO light off .... BUT it all repeats again in another five minutes.
    This oven is 7 years old, but has had extremely light use. I live in a housing development where this was the standard oven installed -- virtually everyone has had problems with this oven, some as early as the first year. Local repairmen have admitted to my neighbors that this GE model is a lemon! Surely GE is aware that this is an inferior product -- they should offer replacement or compensation to their customers!
  • belmB Dec 27, 2008
    When we tried to turn the oven on we kept getting the 666 error code? We also turned off the breaker switch per manual instructions but it did not solve the problem. Could you help with some advice?
  • cathyf Jan 18, 2009
    I have the same problem, with the same ovens.
    I did pay to have it repaired, but not long after...., the same thing started. I have to shut off the circut breaker to the oven when not using or the timer will beep every five minutes! This is honestly the worst appliance I ever owned. It is definately a lemmon, but I doubt GE will ever admit to this.
    My advice is to tell evryone you know...never buy a GE appliance!
  • Anonymous Apr 08, 2009
    Same FO display. Even after turning off the breaker, hours later it constanly beeps and displays the FO error. Piece of ****!!!!!
  • Anonymous Apr 12, 2009
    same thing here, it is really furestrating, we should try to do some thing about it like take GE to court
  • Anonymous Apr 13, 2009
    Did anyone ever figure out how to solve the problem? I tried the bs solutions offered in the manual, still 666 and beeping.
    What part is needed to repair? Is it possible to repair?
  • Rajeev1234 Apr 27, 2009
    GE double oven, keep saying FO for both top and bottom oven and does not start, closed the power and restarted a couple of times and it wont work. Hardly used Oven.
    Did any of you have success finally getting it fixed? really appreciate if you can tell me what was the fix
  • Anonymous May 24, 2009
    GE PROFILE ELECTRIC BUILT IN OVENS. When both ovens are in operation one door locks and the oven goes off.
  • 706 Answers
According to the GE User manual... any F# error code means you have a function error and they suggest you press the CLEAR/OFF pad and allow the oven to cool for one hour. Then put the oven back into operation. If the function code repeats, disconnect all power from th eoven for at least 30 seconds and then reconnect it.. If it still comes back.. call for service.. however it has been my observation that F0 is usually a shorted off key on the keypad. Hope this helps..
Posted on Sep 22, 2008
6ya staff
SOURCE:
How do I clear an error code FO on my GE oven
it usually means the touch pad or the oven control is defective.
Dec 05, 2015 | GE Ovens
FO ERROR ON OVEN
Seems F0 is a problem either with the control panel or with the key panel
Here is a test to find out whether its your control panel or control board:
Determine if problem is with the Key Panel or Control by:
1. Pushing CLEAR/OFF pad.
2. Disconnecting Ribbon Cable from control and waiting at least 32 seconds to see if Code recurs
If code recurs, problem is in the control. Replace control.
If code does not recur, problem is with the Key Panel.
You can go to this site to find replacements
Mar 14, 2008 | GE Profile JKP56 Electric Double Oven
Ge double oven f1 error model jkp55wot1
F-1 error code.
Sometimes one or more buttons on the touch panel "get Stuck"
Nothing you can do to reset them, Good Luck.
Many times it means the touch panel needs to be replaced.
Jul 09, 2014 | GE Profile JTP56 Electric Double Oven
I keep getting FO code and beeping won't clear
Hello George,
The F0 error code means that the computer thinks a button on the touchpad is stuck. Sometimes this can be resolved by making sure the touchpad connector fits tight into the control board. The F0 code can be cleared by pushing CANCEL/OFF. If it returns the touchpad needs to be replaced .
GENE
Oct 05, 2011 | GE Profile JKP56 Electric Double Oven
Double wall oven F0 error code
The F0 error code means that the control board has detected a defect within the control board itself, the F0 code can be cleared by pushing the CANCEL/OFF button and if it goes away and returns all is well,however if a short time later the F0 returns the control board would need to be replaced.
GENE
Oct 04, 2011 | GE Profile 30" Built-In Double Electric...
My GE Profile oven is beeping every minute. I've
if its an f-7 error code its due to a stuck error code
Feb 06, 2010 | GE Profile JT955 Electric Double Oven
The upper and lower oven will not turn on there is power to it and clock and oven lights work there is an FO red light that comes on and beeps and flashes
Built In Oven Fault Codes
F0 or F1 - Failed transistor in control - If code cannot be cancelled, replace the Electronic Range Control (ERC) or touch pad
Sep 21, 2009 | GE Profile JTP56 Electric Double Oven
GE JT912-30 single wall oven "help" with F7 - F0 error
I have a double oven GE Profile. The error message FO appeared. I shut off the circuit breaker for 30 minutes or more and the oven works but without warning FO reappears. FO message means there is short in the clear Off touch button. The only solution replace the complete panel. My cost delivered $328. Ouch!
Jan 19, 2009 | GE Profile JKP56 Electric Double Oven
JTP56 Double Oven Beeping and Display FO Code
http://www.fixya.com/howto/h155060-dreaded_f7_error
May 18, 2008 | GE Profile JTP56 Electric Double Oven
Fo function error code
The F0 usually means that there is a problem with the keypad.
My solution for the F7 problem may help. You will find my solution at the following link.
http://www.fixya.com/howto/h155050-dreaded_f7_error
I have now shared my fix with over 1600 folks and most report success. I hope that it works for you too. Please let me know at:
hutchipop@yahoo.com
Charlie Popeck, P.E.
Consulting Engineer
Mar 07, 2008 | GE Profile JKP56 Electric Double Oven
GE Profile JTP56 Electric Double Oven Logo
2,208 people viewed this question
Top GE Ovens Experts
William Miller
William Miller
Ekse
Marvin
Marvin
Are you a GE Oven Expert? Answer questions, earn points and help others
