A number of reasons for this, poor quaility fuel causing vapour lock, over heating due to starter cover vents blocked,cylinder fins clogged, running too lean on the carb mixture settings, fuel tank breather clogged ( slacken off fuel cap when it starts to die, if it picks up again, replace tank breather, or ignition unit breaking down when hot ( only cure is to replace the unit )
Sounds like ignition problem, click overheating or spark plug is not correct. I pressume isn't fouled by to rich mixture of oil. Be sure to not over work saw as it shouldn't be cutting into wood for much longer than 5-10 seconds for each pass.
Keep chain sharp and make sure bar is lubed.
