Maytag PAV2300 Top Load Washer Logo
Anonymous Posted on Oct 10, 2011
Replace thrust bearing maytag PAV2300 - Maytag PAV2300 Top Load Washer
Gere knutson
Level 3:
  • Maytag Master 842 Answers
  • Posted on Oct 11, 2011
Gere knutson
Maytag Master
Level 3:
Answers
842
Questions
Helped
218277
Points
2087
This link is a picture of the thrust bearing and it's order of how it needs to be replaced. Item number you are looking for is 24.
I hope this helps
I’m happy to help further over the phone at https://www.6ya.com/expert/gere_bf68e6055dd61249
Where do you get the tool to compress the spring when replacing Maytag top load thrust bearing? Even with the .032 washer, I can't get it on.
Hello, Thank You for using FixYa. I will be helping you today.You dont use the spring tool when replacing the thrust bearing. Only when removing the brake.It can be hard to get on but no special tool needed.
Thank You and please rate my answer if it was helpful..
6helpful
Spin Cycle is slow
new belt or there is a thrust bearing above the drive pulley that wears out.
6helpful
Have a maytag model PAV2300 Aww it grinds i have
gringing noise is never a good sign check the main bearing these are notorious for having bearings go and if it is bearing find a new machine its not worth fixing it is costs more then the machine is worth to replace
1helpful
Maytag PAV2300 - Washer agitates during wash. on spin cycle motor runs and belt is fine, but drun does not spin. Water drains. Why does it not spin?
Hi, The most common problem is the thrust bearing kit. The thrust bearing is located on the lower shaft of the transmission. The kit includes a new pulley and hardware. The part #12002213 also includes instructions.
Please let me know if this helps you or if I can assist you further.
Thanks
Vic
SPIN CYCLE DOES NOT WORK
If the motor is running and the water gets pumped out but no spin, it probably needs a thrust bearing kit, which consists of a new pully, bearing and cam.
Maytag MAV2755AW
All you will need is a 12002213 thrust bearing kit and new belt , the bearing comes with instructions , lay unit on front to do this you schooled not need a transmission
Maytag Washer PAV2300AWW
Your Thrust bearing on the bottom of the transmission is not releaseing the break. try turning the pulley with the belt off in the opposite direction this should free up your break. If it doesn't replace your brake ststor and rotor as well as your thrust bearing. This should solve your problem. Roger
Will not spin
Ap, start with the tub and basket, make sure there isn't anything caught in between preventing it from spinning. Im assuming you already checked the belt. Next would be heavy duty stuff like the thrust bearing and brake. The brake may not be releasing. You can check this by turning the pulley counter clockwise slowly and seeing if the transmission spins. If not, the thrust bearing and brake may be bad. There was a number of service flashes out on this model concerning the thrust bearing, transmission and seal kit, vibration in spin and snubber kit. These things may be covered under warranty. In the event it's your transmission, it has a 5 year warranty on it....Catriver..post back.
Top Maytag Washing Machines Experts
Ronny Bennett Sr.
Ronny Bennett Sr.
ZJ Limited
ZJ Limited
Are you a Maytag Washing Machine Expert? Answer questions, earn points and help others
