Question about Sears Craftsman LiftMaster Chamberlain Garage Door Opener Wireless Keypad Model 976LM Security+
Reprogram key pad for garage door opener
Need to reprogram
  • dsf1 Nov 02, 2009
    I bought a house and wanted to reprogram the keypad for the Chamberlain LiftMaster garage door keypad. I followed the directions on the keypad flip door. I punched in the old 4 digit code and held down the # button until the overhead light flashed two times. I then pushed the learn button on the back of the opener itself. Then I punched in the new 4 digit code and pressed the enter button. Nothing happened. Now I can even get the keypad to work with the old code numbers. Any ideas on what to do?
  • 18 Answers
To program the keypad, you will have to press the LEARN button on the back of the garage door opener console and when it begins to flash, enter a new 4 digit code on your keypad and press enter. You should hear a click and see the lights on the opener flash.
Posted on Feb 18, 2009
6ya staff
SOURCE:
pgh_pa_guy
  • 2992 Answers
SOURCE: craftsman outside keypad
On the back panel of the opener itself is a small pushbutton. Press the button and the indicator near it will light. While the indicator is lit, enter the new 4-digit code on your keypad and it will be set. (You are actually programming the receiver with the new code this way. The wireless keypad doesn't store a code.) The programming light goes off on its own.
Posted on Feb 13, 2009
Anonymous
  • 121 Answers
SOURCE: Garage Door Key Pad
Assuming, from what I read, the remote works..The inside switch is just a doorbell switch which will wear out or have the contacts get bent or dirty. Take off wall, and change for new one or see if the contacts can be cleaned or adjusted. If the pad is electronic (coded) the wires may be bad or the control defective. Usually momentary contact of the two wires will cause the door to actuate.
Posted on Apr 21, 2008
Vince Heuser
  • 118 Answers
SOURCE: Key pad won't open garage door
You probably have an eletrical device that is messing with frequency. Make sure that everything is off inside garage.
Posted on Jan 19, 2009
Don Maggard
  • 3197 Answers
SOURCE: How can I reprogram my keyless pad?
If you mean wireless keypad it is like this. Locate the smart/learn button on the rear of the motor unit near where all those white wires go. Press and immediately release this and then walk over to your keypad and key in your 4 digit code and press enter.
Posted on Oct 19, 2009
Don Maggard
  • 3197 Answers
SOURCE: My lift master security plus keyless entry pad for...
You can try programming it but first make sure the battery is good. Locate the smart/learn button on the rear of the motor unit near where all those white wires go. Press and immediately release this and then walk over to your keypad and key in any 4 digit code you like and press enter.
Posted on May 24, 2010
I have a Sears Chamberlain garage door opener pad outside my garage. The 9V battery died and I have replaced the battery. How do I reprogram the pad?
You shouldn't need to reprogram the pad; it functions as before simply sending a signal to the opener that has the programing saved in it.
May 06, 2011 | Sears Craftsman LiftMaster Chamberlain...
My lift master security plus keyless entry pad for the garage door no longer will open the garage door when I key in the four digit code. Can I reprogram the entry pad and if sohow?thank you
May 20, 2010 | Sears Craftsman LiftMaster Chamberlain...
Need to reprogram sears garage door remote opener
Click below to get to the manual you need. Just scroll through till you get to your model number.
http://www.managemyhome.com/mmh/owner_manuals/search?query=GARAGE+DOOR+OPENERS&find=
Hope This Helps,
RSMITH972278
P.S. PLEASE RATE ME
Nov 15, 2009 | Locks & Locksmithing
Oct 19, 2009 | Sears Craftsman LiftMaster Chamberlain...
I have a 1/2 hp Sears Craftsman garage door opener dated 7/96 Canada I reprogrammed the remotes but I cannot reprogram the key pad. I push the square button and have someone punch in four numbers and hold...
If you have a wireless keypad you need to do just what you are doing except after pressing the last number you need to press enter. If your keypad is hard wired post back because the instructions are not the same.
Jul 08, 2009 | Sears Craftsman LiftMaster Chamberlain...
Liftmaster key pad opens door with a single number punch
You are using a universal keypad and usually the 0 button is "enter" look up directions for the brand keypad you are using
Jan 17, 2009 | Sears Craftsman LiftMaster Chamberlain...
Can't reprogram the remote controls.
The light indicator comes on but it never connects with the remote control & I have to reprogram the key pad when, I follow the directions on the unit.
Dec 01, 2008 | Sears Craftsman LiftMaster Chamberlain...
Sears Craftsman LiftMaster Chamberlain Garage Door Opener Wireless Keypad Model 976LM Security+ Logo
1,987 people viewed this question
Top Sears Building Materials Experts
Mike
Are you a Sears Building Material Expert? Answer questions, earn points and help others
