Samsung SCX 4521F All-In-One Laser Printer Logo
Anonymous Posted on Oct 10, 2011
Samsung printer scx-4521f need smarthru4 scanner software
Anonymous
Level 1:
New Friend:
  • Contributor 1 Answer
  • Posted on Oct 10, 2012
Anonymous
Contributor
Level 1:
New Friend:
Answers
Questions
0
Helped
2995
Points
Need a reliable site to download smarthru4 scanner software for Samsung printer scx-4521f
Rudi hattingh
Level 2:
Champion:
  • Samsung Expert 214 Answers
  • Posted on Oct 10, 2011
Rudi hattingh
Samsung Expert
Level 2:
Champion:
Answers
214
Questions
7
Helped
72995
Points
344
Dave O.
Level 2:
Habit-Forming:
Greenhorn:
A rookie expert who has answered 20 questions on their first day.
  • Expert 101 Answers
  • Posted on Sep 20, 2019
Dave O.
Expert
Level 2:
Habit-Forming:
Greenhorn:
Answers
101
Questions
0
Helped
25432
Points
227
Try this site, https://samsung-printerdrivers.com/samsung-smarthru-office-2-software/
1helpful
Unlocked samsung scx 4521F scanner
PLEASE REFER TO IT MANUAL. IF NOT FOUND IT PLEASE CONTACT THE NEAREST MANUFACTURE IN YOUR AREA
I Lost my software for Samsung Scanner printer scx-4521f
Dear
The software can down loaded from samsung website at support and download select your printer model and OS type UNIVERSAL driver may download, The files to be down load are printer driver,scanner driver,and additional application for easy use smart panel and smar thru.
Printer Support SAMSUNG India
Thanks.
1helpful
I want to download software for this scanner model..
Check the below link:-
http://www.samsung.com/in/consumer/pc-peripherals-printer/laser-printer-multifunction/mono-laser-mfp/SCX-4521F/XIP/index.idx?pagetype=prd_detail&tab=support
Scx-4521f scanner hook up instructions
install the software and read the manual. Download it here:
http://www.samsung.com/ca/support/download/supportDown.do?group=printermultifunction&group_cd=&type=printermultifunction&type_cd=06010000&subtype=monochromemultifunction&subtype_cd=06010300&model_nm=SCX-4521FG&dType=D&mType=&model_cd=&menu=download&menuLink=%2Fsupport%2Fdownload%2FsupportDown.do&prd_ia_cd=06010300&disp_nm=SCX-4521FG
I HAVE Samsung SCX-4521F All-In-One WOULD YOU ANSWER ME PLZ
Please chepue out the scanner ccd is not moving properly
when ccd is stop in one place the image will come sreached
or check the scanner cable or check ccd
2answers
Problem scanning with samsung scx 4521f
Sorry to have missed your initial posting...
In any case, to my understanding, this particular printer is likewise capable of USB connection. Perhaps you can try connecting it pure USB and go through the installation again. this might simplify interface and communications between notebook and scanner/printer.
If for some reason you would want to retain Printer/Parallel to Notebook/USB, you need to check your Imaging Devices in the notebook's Device Manager and verify that all drivers are installed for the Samsung SCX-4521F. There should be no yellow or red marks. If there are or if the Samsung SCX-4521F instance is not present, you may need to reinstall using the Add Hardware Option in the Control Panel. You may need to manually select the imaging device/scanner. This holds true if you are using Windows XP.
If you are using Vista, you may need to download all the Vista drivers from the Samsung website. Further, pls be informed that to my knowledge, Vista has certain issues with USB ports. Microsoft has issued a patch/update specifically for this concern. It may be downloaded from here or here.
Hope this be of help/idea. Pls post back how things turned up or should you need additional information.
Good luck and kind regards.
Top Samsung Office Equipment & Supplies Experts
Grand Canyon Tech
Grand Canyon Tech
Norman Weimar
Norman Weimar
Are you a Samsung Office Equipment and Supply Expert? Answer questions, earn points and help others
