Why do the fan stay running when car is off on my 03 crown vic?
Sounds like you have a double problem . First locate the radiator fan relay it should be in the fuse box change the relay. Also change the tempature sending unit (attached to radiator) . If your car is overheating . You need to check. For a leak, be sure you have enough. Fluid in radiator, check. Thermostat , change it anyway cheap enough, ( 16 lbs. pressure ) this should solve your problem
