Sony KDL55HX800 55 in. TV Logo
Anonymous Posted on Jun 07, 2017
I have a SONY 55" KDL55HX800. Two problems: 1.
City View TV & Computer, Inc.
Level 3:
Master:
  • Sony Master 453 Answers
  • Posted on Oct 30, 2017
Sony Master
Level 3:
Master:
Answers
453
Questions
Helped
147674
Points
1036
1. Reset the TV: Turn the TV on, by press & hold the arrow UP button, push the power button the TV to turn off the TV.
2. Log on SONY website to download & update the firmware.
I hope that it could be help.
5 Related Answers
A
Anonymous
  • Posted on Apr 02, 2008
SOURCE: Sony Bravia KDL 52XBR-4
FXFVX
Anonymous
  • 84 Answers
  • Posted on Apr 06, 2008
SOURCE: Can't remove AV Input display
Try setting hdmi control to off in tv menu
Luis Amado
  • 129 Answers
  • Posted on Jun 29, 2008
SOURCE: Sony Bravia TV went Blank
COULD BE LVDS CABLE LOSE OR NOT MAKING A GOOD CONTACT , IF IS NOT THAT UNFORTUNATELY IT WILL BE NECESSARILY TO REPLACE T CON BOARD
YOUR RATING TO MY ANSWER ITS HIGHLY APPRECIATE
THANKS
Anonymous
  • 320 Answers
  • Posted on Oct 19, 2008
SOURCE: KDL-32XBR6
Try resetting the TV by holding down the "up" button on the remote (with the TV powered on) and then, while you hold down the up button on the remote, hit the power button on the TV. This should do a "factory reset" which will wipe all settings in the TV. There is no reason why the TV should not "remember the last input it was on when it was ;last turned off. Also be sure that the TV is not plugged into a switched AC outlet, like the outlet on the back of the cable bix. The TV should be plugged into an output that receives power at all times.
Anonymous
  • Posted on Nov 26, 2010
SOURCE: I have a sony bravia
You Tv has a bad LCD panel... Very expensive...
About the Sony Bravia Kdl55hx800 55" Lcd Tv
The 12 volts comes FROM the power supply board.
TV Parts Universal TV Stands DLP Chips ShopJimmy Go to this web site. You will find repair parts kits as well as complete boards there.
Broken lcd screen
Sure, blame the kids. Could it have been a sporting event and your team lost? Just kidding, dump the screen and case. Sell the boards on ebay.
Sony KDA50R550A tv cannot see antenna
Check and replace its tuner. It is faulty. If you wish to get some details; check the site linked here. Viewing it in "Mosaic" will make surf easy.
USB formats
Download its user manual by internet. Check http://www.retrevo.com/. Manual will have all details.
Sony KDL hx800 red led blinking 4 times
Hi
4 Times Blinking is for
BALANCER_ -------> Panel Balancer Error
4 times-yhodbwzjdt0opvz5rorrwsay-3-0.jpg Kind regards.
Rehan
2helpful
2answers
2005 Sony rear projection 55
To help I need to know what your problem is and confirm model number
I have a 55" Sony
Tries tv unplug,replug it back about an hour later for tv to do a resetting itself back to the factory setting.The tv now should be working again.If tv still have the same problems,the tv power supply board is the causes and the problems.That the board where the power a/c cord plug into it.Tries websites like Shopjimmy.com,Ebay.com to buy a whole new refurbish power supply board for the replacement.
I have a Sony KDL55HX800 and it blinks in a Red light 5 time pattern. Any Ideas?
  • Five blinks - AKB circuit (automatic kine bias), the timer/standby indicator blinks for about 30 seconds then goes to the self-diagnosis function. Something is wrong with the video. Check video out, Q705, 732, 761 and other components on the C board, also check Q218, 219, 220 on the A board. In addition, unit could be in IK blanking, try turning up screen slightly.
  • Not finding what you are looking for?
    Top Sony Televison & Video Experts
    Grand Canyon Tech
    Grand Canyon Tech
    ZJ Limited
    ZJ Limited
    matt martin
    matt martin
    Are you a Sony Televison and Video Expert? Answer questions, earn points and help others
