Hello there,
If the refrigerators fridge and freezer is not cooling. You need to check if the temperature is set to the highest. Then you check if the thermostat is still working.
Then you check if the compressor and fan are running. If they are, then it simply means all you need is to refill the gas tank with some freon or refrigerant as you may know it by.
All the best
Elect_Comp
