SOURCE: I have accidentally blocked a
Settings > Applications > Messages > General settings>Block Messages.
Delete the no you have blocked.
Testimonial: "A One!"
SOURCE: samsung wave gt-s8500. how do
Go to messages>settings>general settings>block messages>then delete any blocked numbers you accidentally blocked! hope this helps. :)
SOURCE: i have accidentally blocked a
Hi To unblock the accidentally blocked number you need to do the following Press the MENU key Select MESSAGING Scroll down the list and select SETTINGS Select TEXT MESSAGE Select BLOCK NUMBER Highlight the number you wish to unblock and select OPTIONS Select DELETE Select either DELETED SELECTED or DELETE ALL and press OK Briefly press on the ON/OFF button to return to the Main Screen
Testimonial: "Thanks very much, worked perfectly. "
SOURCE: How to overcome error of
YOUR MOBILE DISPLAY RESOLUTION OR PIXEL IS 240X400 HERE IT THE SOFTWARE TO CONVERT VIDEO IN RIGHT FORMATION DOWNLOAD THIS SOFTWARE THE LINK IS http://www.megaupload.com/?d=9ZOPRGAQ 1] Install
[2] Use Serial provided to register
code: 308529876O7300I779741E74-C568-6382-E469
code: 555443568Q9676O21923B9D6-B5E1-647A-577C
code: 021685166O5807P60476AEC2-257D-BCFD-4644 THANKS
SOURCE: HOW CAN I REMOVE WIDGET
I think the Widget in the Home screen is in-built.
Just click the widgets button, you can see the bottom, available widgets appears... just drag and Drop widgets to keep in screen and remove from screen.
can anyone help me,incidently i blocked my brother number ,but now not able to unloack it -my model is samsung gt-c6712,can anyone tell me the solution
