SOURCE: Camera problem
ok ...your phone needs to reprogram it uploading the same version of your firmware... it might be somehow corrupted,,gotta go to u'r service center.... if it is still the same hardware failure...need to repair the ram of your phone...(random acces mmemory.)
SOURCE: Micro SD NOT WORKING (SONY ERICSSON W580i)
You need to buy a different kind. i just bought a 4G Microcenter brand and its doing the same thing.
i'd recommend a Sandisk M-2 microSD.
SOURCE: not recognizing micro sd memory card
the M2 card used in this phone is little expensive but SD card will not work for sure.
Also the cheap M2 cards have problems of saving images to un-readable format.
make sure you use sony original or Sandisk card which i've seen working fine on this model.
SOURCE: Suddenly phone cannot detect memory card and camera does not work
It is due to the damage of internal Ic.So you have better to send it to a service center.
SOURCE: i am getting error message that sd card is blank
The problem could be your SD card. Try your SD card on a friends phone. If the same problem occurs, get your SD card repaired. Most SD card companies provide you with unlimited warranty so there should not be a problem.
Installing SD Memory Card
Your camera has a memory card slot that enables you to insert any "SD" compatible memory card up to 8BG. Adding a memory card will allow you to increase the capacity of your camera before you have to transfer photos and videos to your PC. Install the SD memory card as below:
Note:
