As You may know, Whirlpool also builds Kenmore products, that being said, You would be far better off buying the exact model door for Your oven. The joy You may get from saving a "C" note on an alternative door option could turn into a Personal B*tt Kicking contest when You discover it almost worked, You CAN'T send it back and You still have to buy the right one. Best of Luck to You.
in the back there is a cover and under there is a pc board / it may have burnt the board and will require a replacement . ck the glass fuses on the board . and if one has gone bad then rep the board . you could refuse the board . but this diesn't always work . as they didn't make the be refused .. mm
You need someone to open the cover on the compressor and examine or replace the start relay, start capacitor and motor windings. One of those 3 are not working properly.Is the model number you gave made for and sold in the UK? Sea Breeze
hi. thanks for the question .there is a part that could cause a no defrost problem, in the freezer. its the defrost termination switch. when replacing the fan motor. replace it as well .cheap part, save problems later. thanks the appliance doc
