Hi Gwen,
This TV set doesn't have a digital tuner and you will need a digital converter box to receive over the air channels.
You still an antenna to receive the signal and then to connect it to your digital converter box. The programming should be easy.
The converter box should come with the user's guide on how to hook it up and program it.
SOURCE: KP-46WT520 46 in.
Either IC708 is faulty on the A board or the two pico fuses are blown on the A board PS701 and PS702
SOURCE: color distortion and arched picture
you have a bad or maybe 2 bad stk392-560 ic's..
and or a bad pico fuse on your g board.. (there are two of them and 6 of them under your ic's
You can check with a vom meter. (resistors) Not ic's need special meter for that
Jason
[email protected]
SOURCE: Sony KP-46WT520 Standby Blinks 10 Times
High voltage in TV got problem and thats why TV gives 10 time blink error code.
Qualified TV tech will fix it as its bit complicated fix.
SOURCE: Sony kp-46wt520 blinks 9 times
you can use basic power supply diodes ecg 125s or diodes rated at 60 herts at 2.5 amp. these type of diodes are common to alot of power supply diode bridges and if you have any junk electrical boards then you could borrow them used, don't worry they will last longer than the original new ones which were not very efficient from the start.
SOURCE: what is the bulbs size for the Sony KP-46WT520
That is a specialty bulb. You need to purchace from Sony, online or from a electronics shop. Dont think it even has a size designation on it.
