1) Check the breaker is tripped from treadmill. if do reset wait for 2 minutes.
2) Inspect the power cord for pinch cables, or broken cable, or damaged.
3) see the terminals of power cord is missing or bad contac, and need resolder.
4) after that this relais for open and close this relais send the power to the main motor. and clelan contact the relais for good smooth transmission of voltage. for main motor.
5) Test the motor for 115vac , measure withoud Load. and take your deccision. 6) FiNALLY test the main motor board, for 115 VAC and output for +5VDC.
7) dO NOT USE EXTENSION CORD 8) tRY TO USE REGULATOR VOLTAGE . 9) iNSPECT THE GROUND WIRE IN OUTPUT WALL IS O.K
SINCERELY. Merry Christmas.
ernesto cuadra
managua, nicaragua. c.a
See the easy diagnostic that I did with the block diagram for ilustrate easy and troubleshooting.
