Hotpoint Aquarius WD640 Front Load Washer/Dryer Logo
Anonymous Posted on Oct 08, 2011
Error f01 flashing on machine - Hotpoint Aquarius WD640 Front Load Washer/Dryer
ZJ Limited
Level 3:
  • Master 17,989 Answers
  • Posted on Oct 08, 2011
ZJ Limited
Master
Level 3:
Answers
17989
Questions
0
Helped
14449852
Points
60858
F01 on a Washer Dryer means you have a motor fault.
I suggest check the motor and associated wiring. You may just have a broken wire.
Hope this helps.
  • Anonymous Oct 08, 2011
    how do I check the motor, All wiring sems ok. Thanks
My whirlpool dryer is giving me the F01 error code?
The F01 error code usually means the main electronic control board has failed and will need to be replaced. Sometimes it can be just the thermal fuse causing the error but in most cases it's going to be the control board. If you need more help you can visit the link below and get troubleshooting advice.
Whirlpool Duet Dryer F01 Error
E02 flashing
Whirlpool breadmaker e02 error Questions & Answers - Fixya
www.fixya.com > Forum > Tags > breadmaker e02 error
Ask your Whirlpool breadmaker e02 error questions. Get free ... I am getting F01 andE02 flashing errors and the machine will not go into spin cycle . How bad is ...
Reset innov-is 350 from f01 error
Copied from the user manual:
If error message "F01" through "F09" appears in the LCD while the
sewing machine is being used, the machine may be malfunctioning.
Contact your nearest authorized service center
F01 Error
F-01 flashes when there is a primary control
failure. Replace the machine control electronics.
from http://www.advantagesupplyfl.com/WhirlpoolDryerFaultCodes.html
MAYTAG 3000 F01 CODE
It's probably a weak or failed component on the board. It's a common issue on those machines and the Whirlpool Duets. It's usually burned at the motor relay or heater relay.
F01 error code flashes when there is a primary control failure.
The only thing which will solve an F01 error code is a new machine control board. These is a catastrophic control board failure. Nothing can correct it. The part number you require is W10205977.
2helpful
2answers
Showing F01 error code on readout? what does that mean?
Hi.
It depends on the model. On Whirlpool built machines F01 is EEPROM error, pump drive error, or main relays error.
With Hotpoint F01 means defective triac or defective motor.
I have a maytag EpicZ, model # MHW2600TW00 with an error code of F01. Do you know how to clear this code?
I just had this problem and I kept the washing machine on and flashing f01 and I pulled the power cord out of the outlet while it was still on and it reset it and I could start washing immediately.
F01 Error code
most likely suspect main control bd
3answers
Error Code F01
F01 is not a valid fault code but if it is displaying that and all the lights are flashing the main computer has gone haywire. Possibly the display board (in the plastic panel that houses the buttons) may be faulty but this is unlikely
Top Hotpoint Washing Machines Experts
vince
Paul Carew
Are you a Hotpoint Washing Machine Expert? Answer questions, earn points and help others
