SOURCE: sony vgp-vcc1 webcam blurry!
i've got the same problem, this really sucks.. i cant find anything about it on the net.. any ideas?
SOURCE: Dell inspiron 1545 laptop and the same webcam problem.
open your my computer, click on "c" the system will tell you the information is hidden, click on the link and open up the operating system and look in the drivers or there in C and se if you can find you web cam driver, when you find it you might have to force the opening of the driver to install, and once you do that plug your web cam in and see if the system see's it and installs the drivers for the cam, if you installed the driver origanally witht he web cam installed you will have to remove the web cam and unistall the driver and re install it and then plug the web cam back in, and that should help correct the problem.
SOURCE: Dell Studio 1537 (Vista) Integrated Webcam no longer working??
The issue could be due to a loose connection of the camera above the lcd panel. Try uninstalling the drivers and shutting down the computer. Once done gently press the area around the webcam. Power on th computer. See if you get any new hardware and if it installs. If no. check in device manager. If you still have a bang on the webcam uninstall all usb root hubs and restart the computer. If still no joy power off the computer. You need to hold down the Fn button (Located next to the CTRL button on the left hand corner) and then power on the system. This will take the system to the diagnostics mode. After running the tests run a custo tests on the webcam.
SOURCE: My built-in webcam
Try installing Driver Detective located at path:
http://www.drivershq.com/Drivers/Devices/Dell-Creative-Labs-Integrated-Webcam-Driver/96338/43/Drivers.aspx
I had a similar problem and installing Driver Detective solved it. Hope this works for you.
