Microwave Ovens Logo
Holli Schachle Posted on Oct 04, 2011
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
My microwave/convection oven will not heat up, but the lights and clock work
Anonymous
Level 3:
Genius:
  • Master 1,456 Answers
  • Posted on Oct 04, 2011
Anonymous
Master
Level 3:
Genius:
Answers
1456
Questions
0
Helped
475772
Points
4013
Hello
Look to see if the microwave power cord is securely plugged into a live power outlet. The power cord cannot be loose for proper function. Move other appliances to a separate outlet if possible.
Replace or reset the circuit breaker or fuse if blown or tripped.
Unplug the microwave and wait several seconds before plugging it back in to reset.
Make sure there are no current functions in use. Press "Clear/Off" to cancel any other settings or programs already in progress.
Select a new cooking program and then select "Cook Time." Make a time selection and press the "Start/Pause" pad to begin cooking.
Clock, timer ,key board work ..but set time and it counts down but nothing goes no turntable or heat
Here is a tip that will help you to figure out what is wrong with yourMicrowave Oven....
Basic Microwave Oven TroubleshootingTips
heatman101
2answers
Not heating
If the door sensor thinks the door is ajar, it prevents the microwave from heating as a safety precaution.
I found with my old microwave that tapping on the closed door, right at the latch, with a little bit of force would convince the sensor the door was really closed.
Sharp R-1870 Convection works, microwave doesnt heat
Microwave Oven Basic Troubleshooting Tips
heatman101
ytwyys
Sharp 1870 just quit cooking and no turntable
The fact that the microwave and convection both do not heat indicated that the oven is in demo mode, check the user manual, otherwise it will possibly be a relay not triggering, may need a pcb replacement, check Demo mode 1st....Phil
Microwave part of my GE Sensor Convection Microwave doesn't work
Here is a tip that will help you to figure out what is wrong with your Microwave Oven....
http://www.fixya.com/support/r5508031-microwave_oven_basic_troubleshooting
heatman101
My GE Profile Convection Microwave Oven - Convection not working
heatman101
uijjf
3answers
Convection oven problem
Most of the time the magnetron is defective if the food is not heating up.
In some cases there is a defective low power transformer or other componenents associated with the magnetron.
I would suggest to check the owners manual under the warranty section. Sometimes the magnetron has 5 years warranty.
Good Luck.
Top Microwave Ovens Experts
ZJ Limited
ZJ Limited
john h
Are you a Microwave Oven Expert? Answer questions, earn points and help others
