Well, your Xbox is trying to update. The only thing you can really do is either continue trying until it downloads or just disconnect from the internet and reset your console.
1) make shure you have got a xbox live membership with online playing time left. 2) create a new user on your xbox, sighn up for xbox live and see if you can play it on that account. 3) try sighning in and out of your user a few times. 4) make shure your xbox is connected to the internet. 5)make shure your xbox does not need a update, if so then update it.
if all this fail then consult athe manufacterers online support.
ya it means when u registered with ur 1 month or started the account with a credit card there was an error sighning the account up again if that dosnt work try calling up microsoft
Just delete the profile and recover it. As long as you ONLY remove the profile, all your saves will still work and no acheivements or friends will be lost.
if you hook up your xbox directly to your cpu then you need only a good internet connection and an ethernet cable, if wirelessly the a you need a wireless modem to plug into your xbox. you will also need a credit card when sighning up
1.make sure if you want to sighn into xbox live you make an xbox live connection test and a media test.
2.make sure if you have a gamertag, it says XBOX Live under your profile name and select recover gamertag.
3. if 1 and 2 do not work try changing console settings and/or change gamertag.
give both of these solutions a try.. only 2 ways iv heard to do any type of reseting.. If they dont work then you might have a hardware issue.. There is also a factory reset option in the dashboard under system. might try that too. hope this help, good luck.
