Weber Genesis Silver B Grill Logo
Posted on Aug 11, 2017
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
My Weber Genesis Silver Grill seems to have a gas leak which resulted in a flames shooting outfrom under the middle burner control knob which melted that control knob so now I Can't use that control at all. Front and rear burners still ignite but auto ignition switch/button won't work either(it is stuck in the down position/ won't pop back up when you push it and doesn't ignite)
Steve P
Level 3:
  • Master 3,912 Answers
  • Posted on Aug 11, 2017
Steve P
Master
Level 3:
Answers
3912
Questions
5
Helped
1307667
Points
15904
5 Related Answers
Anonymous
  • 63 Answers
  • Posted on Mar 14, 2009
SOURCE: low/weak flame on Weber Genesis Silver B Grill.
hi my name is mark, could be one of two things the regulator on the propane tank try gently tapping on regulator it could be sticking, and make sure the vent on regulator does not have a spiders web . or the orifices to the burners are restricted. check regulator some are ajustable, some are not. hope that helps. thanks for your question.
gcken
Gary Kenady
  • 140 Answers
  • Posted on Apr 28, 2009
SOURCE: Weber - Igniting the three grill burners (front, middle, rear)
it need a clean
Anonymous
  • Posted on Aug 28, 2009
SOURCE: Problem with gas getting to the front burner
Follow manufacturer's recommendation in resetting the excess flow safety device....(Turn burners and LP cylinder off...Disconnect regulator on cylinder. Turn both knobs to high for at least one minute...Then turn them to off...reconnect the regulator to the LP tank...Turn LP valve VERY slowly (30 seconds) until fully opened..then start the grill in the usual manner. ALWAYS TURN THE LP TANK OFF WHEN DONE USING THE GRILL....
Anonymous
  • Posted on Apr 30, 2010
SOURCE: Back burner won't light on my Weber Genesis Silver A Gas Grill
Only front burner lights (out of three) and it only has flame comming out of half of the tube.
Anonymous
  • 4736 Answers
  • Posted on Jun 19, 2011
SOURCE: I have a 2005 Weber
Jeanne - Did you remove the burner to clean? If not. you weren't able to clean the Venturi Valve, which is part of the burner. Spiders love to get in the Venturi Valve & build a nest. When that happens it stops the gas to that burner. I suspect, that may be the problem. The Venturi Valve, is part of the burner (the open end part) that's closest to you, when you face the front of the grill. It will look like 2 slots (one on each side) cut out of the burner tube, where it fits over the burner orifice. But, you can't see it, without removing the burner. An old tooth brush works well to clean it.
Hope this helped you to solve the problem. Please let me know and Happy Grilling!!
Excessive Flame on Gas Grill
blocked burner needs cleaning , air mixture needs more air /or less air .
20helpful
My weber genesis silver starts up, but doesn't get hot enough to cook the food. Seems like not enough flame out of either front or back burners. I tried Outting in a full propane tank, but that didn't...
Try these steps in order.
  1. Turn off the gas at the propane tank
  2. Disconnect the gas line from the tank
  3. Open the grill lid
  4. Turn all control valves to high
  5. Wait for about a minute
  6. Turn all control valves to off
  7. Reconnect the gas line to the tank
  8. SLOWLY turn on the gas at the tank
  9. Light the grill normally
  10. Your grill should now heat normally
I now have a 3 burner weber gas grill and am thinking of buying a 2 burner weber gas grill - how do you use indirect cooking on the 2 burner grill - will there be one burner that is turned off under the...
Well, I personally, wouldn't want to go from a 3-burner to a 2-burner because I think Weber designed the 3-burner grill to perfection, and as you know, all you have to do is turn off the middle burner.
At any rate, indirect is harder with the two-burner because of the placement of the burners. You can try to put some 1" thick ceramic bricks directly on the flavorizer bars in the middle, or if you are using a rotisserie, put a pan under your meat.
The gas flamed up on the underneath the knob
It's either blockage or a leak at the valve.. Turn gas ogg and trighten valve, the open gas very slowly. before lighting check connection with soapy water.
Our weber grill is suddenly getting too hot... even with only 1 of the 3 burners turned on it is over 400 degrees... any ideas?
Sounds like the regulator is not controlling the flow of gas. Try this. 1. Turn gas tank and burner control knobs off. 2. Turn tank valve on VERY slow. 3. Open front burner knob on and lite grill. Wait a minute and turn on addition burners, (if needed).
14helpful
1helpful
One burner has low flame
Try looking for webs back to where the burner tube meets the valve. Otherwise you need to remove burner tube to access back of valve to clean with a torch tip cleaner or compressed air, (remember to disconnect grill from gas source first) inside valve orifice.  Usually the back of valve can be removed with a wrench. Worst case you always get a new valve off internet if you can't resolve the plug. Hope this helps, good luck.
Top Weber Grilling Experts
Paul Carew
Sean Wright
Sean Wright
Mike Cairns
Mike Cairns
Are you a Weber Grilling Expert? Answer questions, earn points and help others
