Apple iPhone 4 Black Smartphone Logo
Anonymous Posted on Oct 03, 2011
I forgot my Iphone 4 passcode - Apple iPhone 4 Black Smartphone
tonier
Level 2:
Sniper:
  • Expert 64 Answers
  • Posted on Apr 07, 2013
tonier
Expert
Level 2:
Sniper:
Answers
64
Questions
0
Helped
56193
Points
160
William Lee
Level 2:
Habit-Forming:
New Friend:
  • Apple Expert 44 Answers
  • Posted on May 20, 2019
William Lee
Apple Expert
Level 2:
Habit-Forming:
New Friend:
Answers
44
Questions
0
Helped
11563
Points
273
I once also forgot my iPhone passcode and then I searched on the Internet and found this guide is helpful to me.
https://www.joyoshare.com/unlock-iphone-passcode/forgot-iphone-passcode-how-to-reset.html
Anonymous
Level 2:
New Friend:
  • Expert 51 Answers
  • Posted on Oct 10, 2011
Anonymous
Expert
Level 2:
New Friend:
Answers
51
Questions
0
Helped
7127
Points
138
Just plug it into the computer you sync IR with and it should be unlocked
2 Related Answers
Anonymous
  • 20 Answers
  • Posted on Feb 13, 2009
SOURCE: I forgot my passcode to unlock my iphone
It depends on the severity and the settings you have given the iPhone and whether you have the computer that you synced your iPhone with... Here's the full explanation. I would recommend reading the second paragraph first, but the solution if you really forgot your password is in the first paragraph.
==If you have the computer you synced your iPhone with==
If you cannot remember the passcode, you will need to restore your device on the computer that was used to originally sync the iPhone or iPod touch so that you can reset your passcode and resync the data from the device (or restore from a backup). If you restore on a different computer that was never synced to the iPhone or iPod touch, you will be able to unlock the device for use and remove the passcode but your data will not be present. Refer to "Updating and restoring iPhone and iPod touch software."
"If you enter the wrong passcode too many times, you'll see a message that says "iPhone is disabled" and to try again later. If you repeatedly enter the wrong passcode, iPhone or iPod touch will be disabled for longer intervals, before you can try again. After too many unsuccessful attempts, you won't be able to try again until you connect to the computer you normally sync with. Note that starting with iPhone 2.1 software, there is a setting to cause the device to erase itself after 10 consecutive incorrect password attempts. This setting is off by default. It  can be turned on by tapping Settings > General > Passcode Lock after you enter a correct passcode."
The full article can be found here: http://support.apple.com/kb/HT1212
==If you don't have the computer you synced your iPhone with==
If you don't have the original computer the iPhone synced with, the only solution is to force your iPod Touch into recovery mode and then restore it. You will lost all the data on the iPod Touch, but after this method is done, everything will work. You can find the steps to solving this problem here:
http://support.apple.com/kb/HT1808?viewlocale=en_US
Anonymous
  • 192 Answers
  • Posted on Feb 21, 2011
SOURCE: i forgot my apple iphone
Try the Restore procedure from iTunes If you have problems. But first try the recovery procedure.
1.
Disconnect your iPhone cable but leave connected the other USB end to the computer.
2.
Turn off your iPhone holding the Sleep/Wake button. The red slider bar appears. Slide the bar and wait until the iPhone turns off. Or you could hold the Sleep/Wake and Home buttons at the same time until the iPhone turns off.
3.
While pressing and holding the Home button connect the USB cable to your iPhone. It should power on. Hold the Home button until you see the "Connect to iTunes" message. Open iTunes if necessary. You should see the "iTunes detected an iPhone in recovery mode..." alert screen.
Choose " Restore"
I forgot my passcode to my iPhone 6 plus
If you forgot the passcode to your iPhone, there still are a few methods to reset the passcode. Check one of them shown below.
If you have synced your iPhone with iTunes before you forget your iPhone password, you can reset your iPhone by using iTunes without losing data. Through iTunes, you can restore your iPhone from the last backup and remove the passcode from your locked iPhone while retaining your data. If iTunes asks you to enter the passcode, try another computer. Otherwise, you have to follow the reset iPhone Passcode with Recovery Mode section below. The following steps will show you how to reset iPhone password with iTunes.
Step 1. Connect your iPhone to the computer with via a USB cable that your iPhone has trusted.
Step 2. Launch iTunes. If you've synced your iPhone with iTunes, then no "enter password" is required.
Step 3. iTunes will automatically sync your iPhone and create a backup file. If it doesn't, you should sync your iTunes and create a backup file manually by in the Summary window.
Step 4. In the Summary window, you can see the option "Restore iPhone". Click it and follow prompts to choose the latest iTunes backup to restore your iPhone.
After the restoration process is complete, your passcode will be erased and all your data will be restored from your backup. You will now be able to access your iPhone without any passcode. And you can set your new password on iPhone.
For more methods, check: How to Reset Password on iPhone
3answers
Iphone s5 passcode removal
You can simply follow the steps below:
1. Connect iPhone to computer.
2. Select iPhone in iTunes "Devices" and click "Summary".
3. Click "Check for Update" to see whether there is a new version for iPhone software.
4. Click "Restore" and follow the instructions to complete the restore process.
5. Choose "Restore from iTunes backup" when iOS Setup Assistant asks to set up your iPhone.
Or refer to the source page: Forgot iPhone Screen Lock Passcode How to Recover Lost Data on iPhone...
2answers
How to reset restriction passcode
JUST RESTORE YOUR PHONE IN DFU MODE WITH LATEST UPDATE
ALL DATA WILL BE LOST SO BE SURE TO BACKUP ALL
FOR DFU MODE
CONNECT YOUR PHONE TO PC
HOLD POWER + HOME BUTTON WHEN SCREEN GOES OFF
COUNT UPTO 6 AND RELEASE POWER BUTTON WHILE HOLDING HOME BUTTON
3answers
Reset my password on iPhone and i pad
iPhone must be recovered on a PC or Mac to solve this problem.
CLICK HERE
2helpful
Need to change iphone passlock code
http://osxdaily.com/2011/01/16/forgot-iphone-passcode-how-to-reset/
this will help you!
nouvelle tablette pc
4helpful
I forgot the 4 digit passcode for my iphone. Can
If you forgot you can generate master code using your IMEI, which can be viewed by pressing *#06# and keying that in the link mentioned below,,
http://www.unlockme.co.uk/master.php
1helpful
2answers
Forgot my passcode
Bad News... you may have to Restore from iTunes. Here is some info from the users manual:
Passcode Lock By default, iPhone doesn’t require you to enter a passcode to unlock it. Set a passcode: Choose General > Passcode Lock and enter a 4-digit passcode, then enter the passcode again to verify it. iPhone then requires you to enter the passcode to unlock it or to display the passcode lock settings.
Turn passcode lock off: Choose General > Passcode Lock, enter your passcode, and tap Turn Passcode Off, then enter your passcode again. Change the passcode: Choose General > Passcode Lock, enter your passcode, and tap Change Passcode. Enter your passcode again, then enter and reenter your new passcode.
If you forget your passcode, you must restore the iPhone software. See “Updating and Restoring iPhone Software” on page 204.
Set how long before your passcode is required: Choose General > Passcode Lock and enter your passcode. Tap Require Passcode, then select how long iPhone can be idle before you need to enter a passcode to unlock it.
Top Apple Cell Phones Experts
Grand Canyon Tech
Grand Canyon Tech
ADMIN Andrew
ADMIN Andrew
Paul Bade
Are you an Apple Cell Phone Expert? Answer questions, earn points and help others
