SOURCE: konica minolta driver
Try these links: http://www-user.tu-chemnitz.de/~choc/minolta/mirror/ca.konicaminolta.com/support/americas/software/dimage-series/dimage-viewer/software_drivers/index.html http://kmbs.konicaminolta.us/content/support/supporthome.html
SOURCE: konica minolta dimage x1
Of course this problem can be fixed but only temporarily..This is the main problem with LCD screen displays.Either you replace the screen and use it for the time being or sell it off before the liquid leaks out completely.
SOURCE: camera wont turn on even with new batteries
taking the battries out then hold dowin the power bottom worked!!! THANKS
SOURCE: Konica Minolta DiMAGE 7i Digital Camera Problem
I just found a solution to my camera problem. It turned out to be the
batteries. We purchases some Rechargable Duracel with a 2650mAh rating.
After charging the batteries I put them in the camera and it started
right up and was taking photos like when we first bought it. I have not
been able to use the camera in almost 2 years and it turns out the
problem was weak batteries.
So anyone that has a Minolta Dimage
7i and cant get it to turn on make sure you have at least 2650mAh rated
rechargable batteries. The higher the mAh rating the better.
Hope this helps someone else. We are ecstatic that we can use our camera again. No more using my camera phone!!!
