I am assuming that you have enabled the wireless networking in the wireless network setup menu, and then pushed on the connect to wireless network. If your router is not set to broadcast your SSID, then you need to refer to the Advanced Network Settings. If the router is too far away, that can affect the signal, or any obstructions in the path of the signal. You could try a signal repeater in the path from the router to the Acculink Unit. They make some that just have to be plugged in to an electrical outlet, like plugging in a lamp, etc.
First Option: Phone in the Other Sim and check the Phone Network Signal If Network Signal Problem not Solved So Secend Option: Your Phone Network IC Fault So Please change Network IC And Network Signal Problem will Solved if it is there isn't much you can do on this side of the network. Contact your phone company.
If you have done it properly there is no need to bridge networks because there should only be one. The entire idea of a repeater is to simply pick up the signal from the first router and rebroadcast the signal.If you had included the model of the repeater I could have been more specific but as it is, read this: Linksys Official Support Configuring an Access Point as wireless repeater
It is possible that the Xbox will be unable to pick up the wireless signal being transmitted by your gateway because the signal is too weak.
The connection speed of your internet has nothing to do with the strength of the signal. The best way to test this would be to try to connect to your wireless internet on a laptop while sitting near the xbox. If you cannot, you will know that the signal isn't powerful enough to reach that location.
There are three common options to amplifying your signal if necessary.
1) Purchase a High-gain antenna for your wireless gateway 2) Purchase a wireless repeater 3) Purchase a new router/gateway with a longer range capability. A "Wireless N" enabled router would be optimal for this application.
I-Pad's work on any wifi signal and pick up both public and private networks. The network you are trying to access is locked by the user or network admin. You can connect it to your own home wireless network or go to a local mcdonald's or something and pick up a public network.
Select from the computers default internet networks, Recent computers are wireless enabled as the prefered networking. Attempting to introduce another network would share the connection capacity to any availabe signals. decide on the network type required. Pick wireless and disable the remaining networks to achieve an express signal reception and transmition.
Check wheather its disabled.and then Scan for the wireless network again and try connecting.make sure thatyour typing correct password if its security enabled network.
mm have u ever dropped the phone or any thing like that if it cant pick up any signal sounds like the internal areal has broken or faulty thats all it could be
