SOURCE: Instructions for Frigidaire oven missing.
I found the manual online. Apparently my unit is malfunctioning and should work by just pressing bake temp and then selecting the temp...
SOURCE: Oven does not work after running self cleaning
Dear Dupe,
please rate this solution if it mends up ur needs,else choose fixya,
please do the following checks,
please rate this solution if it mends up ur needs,else choose fixya.Thank you
SOURCE: Frigidaire Oven - lights are on but no heat from oven or burners
You must check your incoming power for 220 volts. You have lost one leg of your power. Either a bad breaker or bad wall outlet or bad range cord.
SOURCE: frigidaire wall oven will not heat up very fast
The clock control has a relay that turns on the element. It could be failed and would require a new clock control.
SOURCE: model FEFL78CBC frigidaire oven bottom (bake)
We had the same thing happen and now they came and said it was the clock that needs to be replaced. They said that controls the oven. Even though clock is on and working the function for turning on the oven is not
