Is it a hydro? check the release lever some times i forget too. If its gears then try different gear and check that the belt is engaging fully if the clutch spring broke your pedal shouldn't push back up.
there is no clutch,, you have an arm with a pulley that is spring loaded .. when u release the " clutch" this arm pulls a pulley against the belt taking up the slack ,, make sure the belt is not worn ,, or the spring is broken or loose
