Dryers Logo
Posted on Sep 19, 2008
IS60VS Dryer not heating - Dryers
  • allanmotion Sep 20, 2008
    Thanks for your helpful reply, I have already stripped down the Dryer & found that the wiring to the heating element had shorted out to the back panel. I was going to replace the wiring but when I took the Element unit out it was so fragile after years of thermal cycling that the flimsy core support for the coils of the Elements collapsed rendering defunked. I have ordered up a new Element unit which should arrive soon. Again thanks for taking the time to respond
Anonymous
Level 1:
Scholar:
  • Contributor 32 Answers
  • Posted on Sep 19, 2008
Anonymous
Contributor
Level 1:
Scholar:
Answers
32
Questions
0
Helped
20865
Points
92
Dryers could not be simpler devices. I assume that since all you mention is that the dryer is not heating, everything else on the dryer is working as normal. ie. You could put in wet clothes, set the timer start the dryer and the drum starts turning and air comes out of the exhaust. It just happens not to be hot. I am also assuming that you know how to use the drier and that it is not set on tumble (no heat).
If that is the case, the heating element is almost certainly burned out. Basically this is the part of the dryer that glows red (just like an electric stove) when electricity passes through it. Unplug the dryer and see how it can be taken apart. Many open from the top or the back. They are all slightly different. The heating element will be located near the blower fan typically at the bottom of the dryer. Figure out how to get at this, pull the old element out and then replace it with your new one. There will be two electrical connections. You may even see where the element just slides into position by the blower and can be removed with a couple of screws.
You should only need a screw driver to do all of this.
Plug the dryer in and enjoy the warmth.
My dyer Kenmore MODEL 110.87511702 is not heating.
There could be a number of reasons why your Kenmore dryer is not heating. Here are a few things you can try to troubleshoot the problem:
  1. Check the thermostat. The thermostat controls the dryer's heat. If the thermostat is not functioning properly, the dryer may not heat. Check the thermostat and replace it if necessary.
  2. Check the heating element. The heating element is responsible for generating the heat in the dryer. If the heating element is not working, the dryer will not heat. Check the heating element and replace it if necessary.
  3. Check the dryer vent. If the dryer vent is clogged or blocked, it can cause the dryer to not heat properly. Check the dryer vent and make sure it is clear of any obstructions.
  4. Check the power supply. Make sure the dryer is receiving power. Check the outlet and circuit breaker to ensure that the dryer is getting electricity.
I hope these suggestions help! If you have checked all of these things and the dryer is still not heating, it is possible that there is another issue causing the problem. I recommend having a mechanic diagnose the problem in order to determine the cause and recommend the appropriate repair. Let me know if you have any other questions.
2answers
DRYER WON'T HEAT
How To Fix Dryer With No Heat ' Dryer Repair - PartSelect
www.partselect.com/Repair/Dryer/Not-Enough-Heat/
When your gas or electric dryer is not producing any heat or not enough heat to ... If the sensor is defective, either the igniter won't glow or the gas valve won't ...‎How to test a dryer's heating ... - ‎How to open your dryer's cabinet
How To Troubleshoot A Dryer That Won't Heat ' PartSelect ...
? 4:23
www.youtube.com/watch?v=ahb5pt52drE
Oct 6, 2011 - Uploaded by PartSelect
How To Troubleshoot A Dryer That Won't Heat ' PartSelect.com ... If you're using an electric dryer check ...
Oct 30, 2015 • Dryers
Dryer not drying
another user's Q&A for the same issue try that or call may tag, they are supper helpful
Investigate these five areas if your dryer is not heating up:
Proper Voltage
If your dryer won't heat up, it's possible that it is not being supplied with the proper voltage. Here are three ways to make sure power is getting to your dryer: First, make sure your dryer is plugged in. Next, check the circuit breaker panel to make sure all the circuit breakers are in the correct positions. Finally, check to make sure no fuses in your fuse panel are blown. Any of these could explain why power is not getting to your dryer.
8574d88.jpg Heating Element
It is possible that your dryer isn't heating because its heating element is defective. Heating elements are irrepairable. If yours has ceased to function properly, you will have to replace it. Open your dryer's cabinet and locate the heating element so that you can test it.
d5b5af3.jpg Thermal Fuse
Another possible cause for a dryer not heating up could be attributed to a faulty thermal fuse. Once a dryer's thermal fuse has blown, it is no longer of any use. If your dryer's fuse is blown, you will have to replace it. Open up your dryer's cabinet and locate its thermal fuse so that you can test it.
77d6bd4.jpg Thermostat
If any of your dryer's thermostats have become defective, they could be the reason that your dryer is not heating. Open up your dryer's cabinet and test each of your dryer's thermostats. If any are faulty, replace them.
    2answers
    Kenmore dryer not heating up
    If you are having problems with your gas dryer not heating the most common problem is that the ignitor goes bad. Even though it glows sometimes it is still not working properly.
    if you dryer is gas check out this gas no heat tip....
    If you have an electric dryer, you can have many different things that can go wrong causing the dryer not to heat.
    check out this electric no heat tip...
    heatman101
    Dryer will not heat. It would initially heat but then the heat would stop.
    Check out this tip that will give more details…
    Gas dryer not working gas dryer not heating
    http://www.fixya.com/support/r4398592-gas_dryer_not_working_gas_dryer_not
    Check out this tip to see the things that can fail to cause your electric dryer not to work.
    Dryer Troubleshooting Electric dryer wont heat
    http://www.fixya.com/support/r3866345-dryer_troubleshooting_electric_dryer_won
    heatman101
    Dryer won't heat up. It starts to heat then goes off
    heatman101
    LER4634J Electric Dryer: dryer will not heat...
    heatman101
    [p]
    2helpful
    My dryer does not heat. Fuse, thermostats, heat element all have continuity, power chord is good, 240v at plugin... stumped. It is a model # LER4634BQ1 Whirlpool SN# ME4471484
    dryer_heating-element.jpg Heating Element
    dryer_thermal-fuse.jpg Thermal Fuse
    dryer_thermostat.jpg Thermostat
    dryer_timer.jpg Timer motor
    A defective timer motor could also cause your dryer to not heat up. Test your dryer's timer motor. If it is no longer functioning as it should, replace either the entire motor assembly, or just its motor.
    2answers
    Whirlpool dryer will not heat
    Hello there:
    There are 5 things that would not make the dryer heat up i will post you them here ok
    Jan 17, 2010 • Dryers
    2answers
    The dryer does not give heat
    Hello there:
    Proper Voltage
    Top Dryers Experts
    john h
