Uniden DECT 6.0 Cordless Phone ID Logo
Anonymous Posted on Sep 29, 2011
Why do I have "new CID;3 on my screen. Not there
Anonymous
Level 1:
New Friend:
  • Contributor 12 Answers
  • Posted on Sep 29, 2011
Anonymous
Contributor
Level 1:
New Friend:
Answers
12
Questions
0
Helped
1484
Points
30
it's maybe from your's sim's displayed content...at this case go to cell info display then click off..
Thanks.
2helpful
Please help, Main screen for Zenonia 3 was missing plugins
Reinstall the app. It should take care of it.
New phone DECT1480. How do I delete the new cid numbers
To select a number, highlight the number and press Menu/select. The phone gives you the following 3 options:
1) Delete Entry Erase the number from the list.
2) Store Into Pb Add the number to the phonebook. The handset prompts you to edit the name and number.
3) Delete All (CID list only) Erase all numbers from the list.
Friends phone:
1) Check batteries
2) Check base unit has good mains connection ! faulty mains extension
3helpful
Distributor wiring oder for a 80 Ford F150 8 plugs.
255 cid (4.2L), 302 cid (5.0L), 360 cid (5.9L), 390 cid (6.5L), 460 cid (7.5L) V8 engines Firing order: 1-5-4-2-6-3-7-8 Distributor rotation: Counterclockwise
351 cid W & M (5.8L), 400 (6.6L) engines Firing order: 1-3-7-2-6-5-4-8 Distributor rotation: Counterclockwise
Hi! I have Panasonic KX-T7730. My problems are 1. When I answer the phone the number of an outside caller is not displaying on the screen so I can not have the opportunity to see the number well. Is...
The Panasonic system needs 3 things to make CID display work, CID service from the telco, CID hardware, and programming. The card ending in 93 needs to be installed in a TD/TAW/TA/TDA/TDE/NCP series cabinet. In an 824 it's a TA-82493 card, a 3-port card that plugs into a slot in the inside of the cabinet at the bottom (or upper left slot if it's mounted sideways). When it's installed, there are programming options to turn on the display and buttons to program to display and select the last calls (up to 300).
Carl
I have a call display feature with telephone company but can not see any numbers on the phone screen. KX-T7436
It requires 3 things to display CID on a Panasonic system phone, CID service, CID hardware (part number TD-193), and programming. The 193 card is a 4-port card about 3 inches square and it attaches to the trunk card of a TD system.
It was an extra cost item in everything but the -7 cabinet, the last one Panasonic made in the series.
Carl
7helpful
I need a diagram showing the spark plug wires on a ford 302 motor
FIRING ORDERS NOTE: To avoid confusion, remove and tag the spark plug wires one at a time, for replacement. If a distributor is not keyed for installation with only one orientation, it could have been removed previously and rewired. The resultant wiring would hold the correct firing order, but could change the relative placement of the plug towers in relation to the engine. For this reason it is imperative that you label all wires before disconnecting any of them. Also, before removal, compare the current wiring with the accompanying illustrations. If the current wiring does not match, make notes in your book to reflect how your engine is wired. Fig. 1: 300 cid (4.9L) inline six-cylinder engines Firing order: 1-5-3-6-2-4 Distributor rotation: Clockwise 85762008.gif
Fig. 2: 232 cid (3.8L) V6 engine Firing order: 1-4-2-5-3-6 Distributor rotation: Counterclockwise 85762006.gif
Fig. 3: 255 cid (4.2L), 302 cid (5.0L), 360 cid (5.9L), 390 cid (6.5L), 460 cid (7.5L) V8 engines Firing order: 1-5-4-2-6-3-7-8 Distributor rotation: Counterclockwise 85762007.gif
Fig. 4: 351 cid W & M (5.8L), 400 (6.6L) engines Firing order: 1-3-7-2-6-5-4-8 Distributor rotation: Counterclockwise 85762009.gif
Fig. 5: 6.9L diesel engines Firing order: 1-2-7-3-4-5-6-8 85762010.gif
A miss in the firing order I need a digoram of the firing order
1helpful
No CID
This message is in an area that discusses the 25202RE3. If you really have the 202, this model shouldn't have the CallerID capability. If there was ever a model 25204RE3, that model probably has it.
If you bought it brand new, then you might have the space-age chrome/blue-plasma model (2542YRE3?, where Y is either 3, 4, or 5). If Y is 3 (and the model number system holds), you don't have CID/VM. If Y is 4, you do. If Y is 5, you have a built-in answering machine as well.
Top Uniden Lands Phones Experts
k24674
Grand Canyon Tech
Grand Canyon Tech
Are you an Uniden Lands Phone Expert? Answer questions, earn points and help others
