I just got my new jamo i 200, but all it does is charging my i-pod. If I press the power button, either on the remote or the unit itself, nothing happens.
It just does not switch on. Did I get a faulty unit, or is there anything I should have done?
the easiest solution is to get yourself a cord that switches from headphone plug to RCA and connect it that way. I sure hope that this helps you in hooking your ipad up to the Jamo 200 Sub. Thanks, Cody
The Jamo i200 is designed for Apple iPods. The Sansa Fuze is not an iPod, and is electronically incommpatible. In fact, I'm a bit surprised that you haven't irretrievably damaged the Fuze by trying to use it in the i200.
Guess it would be cheaper to buy the DVR-60 , og DVR-70. I recall having seen good publicity on the dvr-60, but guess it would be hard to get your hands on that one. I have found the dvr-70 at the price of aprox. 200£. If you change the "motherboard", it will probebly brake down again, en just as expencive. I believe the cabinet is overheating do to lack of aircirculation, when you open it, there is no dust to be found at all...
This may not be the answer you are looking for but your I pod might not be fully charged, meaning that you are not plugging it in the computer/docking system long enough.( it takes much longer than 15 minutes to charge the battery. So you might want to plug it in/dock it over night) Or you may be playing a game that uses a lot of MB/GB so it kills the battery. And make sure that you press the play/pause button down for at least five seconds before switching the little switch at the top of your I pod. If you don't press the play/pause button for five seconds and just switch the switch at the top a little lock will appear on the left corner meaning you need to hold the play/pause button down for five seconds then the i pod screen goes black at that time flick the switch at the top off.
-hope it helps
owner of i pod nano and I pod touch.
I WOULD LIKE 2 NO IF I CAN RESET MY PASSWORD 4 KLH SURROUND SOUND SYSTEM. I BOUGHT AT A SALE AND THERES NO WAY I CAN FIND OUT PASSWORD. IT IS A KLH SURROUND SOUND SYSTEM DVZ-2500 MODEL # IS 0044224000657.I WOULD ALSO LIKE 2 NO IF AND WHERE I CAN GET A MANUEL....
Just charge the battery until the indicator says the battery is full. well since its been connected for more than enought, disconnect it, you can also try reseting the ipod incase it has frozen
To reset your iPod:
1. Toggle the Hold switch on and off. (Slide it to Hold, then turn it off again.)
2. Press and hold the Menu and Select buttons until the Apple logo appears, about 6 to 10 seconds. You may need to repeat this step.
Tip:
If you are having difficulty resetting your iPod, set it on a flat surface. Make sure the finger pressing the Select button is not touching any part of the click wheel. Also make sure that you are pressing the Menu button toward the outside of the click wheel, and not near the center.
If the above steps did not work, try connecting iPod to a power adapter and plug the power adapter into an electrical outlet, or connect iPod to your computer. Make sure the computer is turned on and isn't set to go to sleep.
