HEWLETT-PACKARD CP1525NW Laser Printer Logo
Anonymous Posted on Sep 28, 2011
I GET HPBCSILNSTALLER.EXE ERROR WHEN i TRY TO INSTALL hp cp1525NW PRINTER WINDOWS 7
How do I disable HP ToolboxFX error alerts
how about installing a new laser jet HP printer tool box fx...
How do I disable my HP Toolbox FX error alerts on Windows 7 when I use my Laser Jet HP printer that is connected wireless to my Samsung laptop
Toolbox is NOT supported in Windows 7 To disable,
  1. Use the Windows Search feature to find the hptlbxfx.exe
    application. Typically, this executable file is found in the following location:
    C:\Program Files\HP\ToolboxFX\bin
  2. Click Start .
  3. Click Run .
  4. Browse to the location of the application, or type the path. Do not click OK .
  5. Add the disabling option by typing -disable
    at the end of the path. The information in the Open field will appear as follows:
    "C:\Program Files\HP\ToolboxFX\bin\hptlbxfx.exe -disable"
  6. Click OK .
1helpful
I have windows 7 and wants to install hp psc 1310 but facing code 43
you probably have the wrong driver installed. Most likely you have upgraded to a 64 bit system, and the driver is 32 bit. Find out which system you're running (right click 'computer' and click 'properties').Disconnect the printer and Uninstall the software, then go to hp website and download the proper software and install here:
1helpful
I want hp psc 1315 all-in-one printer scanner copier Software & Driver
Here are thedrivers . When you click on the links, give it a minute and they will'pop-up' on your screen. When you click 'Save' the driver package willbegin to download. OS Type Version Date Added File Size File Type Download Link (About) Windows XP Driver 4.2.0 - Basic 2008-05-17 48.54 MB exe HP PSC 1315 Windows XP Printer Driver Download Windows 2000 Driver 4.2.0 - Basic 2008-05-17 48.54 MB exe HP PSC 1315 Windows 2000 Printer Driver Download Windows XP 64-bit Driver 1.0 - Beta 2008-05-10 58.43 MB exe HP PSC 1315 Windows XP 64-bit Printer Driver Download Windows Vista 64-bit Driver 080.001.237.000 2008-05-13 163.07 MB exe HP PSC 1315 Windows Vista 64-bit Printer Driver Download Windows Vista Driver 080.001.237.000 2008-05-13 163.07 MB exe HP PSC 1315 Windows Vista Printer Driver Download Windows 7 Driver 13.1.0 2009-12-04 362.68 MB exe HP PSC 1315 Windows 7 Printer Driver Download Windows 7 64-bit Driver 13.1.0 2009-12-04 362.68 MB exe HP PSC 1315 Windows 7 64-bit Printer Driver Download ALTERNATIVEDOWNLOAD LOCATION.
Note: These are LARGE files and may take some time to download.
Save the driver file somewhere on your computer where you will be easily ableto find it, such as your desktop.
After downloading, go to the location where you saved the file and double clickon the file. Then simply follow the on-screen instructions for installing thedriver.
HPPSC 1315 Windows 7 Printer Driver Download
HPPSC 1315 Windows 7 64-bit Printer Driver Download
THE HP SOFTWARE IS AVAILABLE THROUGH YOUR OPERATING SYSTEM. ON WINDOWS CLICKSTART AND THEN SELECT THE WINDOWS FAX AND SCAN ICON.
Software: Download optionsand information Description: clip_image002.png This software installs a copy of the help files onto your computer. Install this software if you did not install from the CD or if you did not install the full featured version of the software. Do not install this software if the help files for the HP PSC 1315 are already installed on your computer.
To see if the help files are already installed on your computer, check the following destination:
Windows XP: On the Windows taskbar, click Start, click All Programs, point to HP, click PSC All-In-One 1310 series, and then click Help.
Windows Vista: On the Windows taskbar, click the Windows icon, click All Programs, point to HP, click PSC All-In-One 1310 series, and then click Help. Details andspecifications File name: clip_image002.png MaggiMinus_Installer_24Nov08.exe [1/1, 24.91M] System requirements: clip_image002.png No additional prerequisites Released: clip_image002.png 2008-12-04 Version: clip_image002.png 1.1 Compatibility: clip_image002.png Microsoft Windows Vista, Microsoft Windows Vista (64-bit), Microsoft Windows XP 64-Bit Edition, Microsoft Windows XP Fix/Enhancement: clip_image002.png Updated the file to make the help files available from the Windows Start menu after installation is complete.
http://h10025.www1.hp.com/ewfrf/wc/softwareDownloadIndex?softwareitem=mp-66177-3&lc=en&dlc=en&cc=us&os=228&product=374568&sw_lang=&key=null&site=null
I’m happy to assist further over the phone at https://www.6ya.com/expert/jeremy_cd01d4e4178e5a11
25helpful
3answers
Cannot install Selphy CP400 onto a Windows 7 (64 bit)machine.
download vista 64bit drivers (cp400x64mux.exe). Extract these using winzip or winrar or 7zip. Rightclick CNYCPINS.EXE, click Properties, click Compatibility tab, and select Vista SP2 mode. Connect printer, rightclick CNYCPINS.EXE and click 'run as administrator'. Printer is now installed, works fine on my Win7 Home Premium 64bit.
Installed usb to db26F converter to use printer
Ok reinstall as Administrator, use "Compatibility mode" for install and the run .exe, also run software as Administrator. too. Often these devices, USB - Serial Ports are NO GOOD for a printer. Either install a real Serial Port. or get a new printer. Windows 7 will NOT help either, it doesn't like older equipment.
1helpful
2answers
Since I have installed Windows 7 on my Computer my Scanner on my (All-in-One) HP F2210 Printer/Scanner will not work...? [email protected] CHARLES
Here is the driver download link for Hp F2210 for Windows 7 (32-bits)
ftp://ftp.hp.com/pub/softlib/software11/COL30101/al-74850-1/DJ_AIO_03_F2200_NonNet_Full_Win_WW_130_140.exe
Here is the driver download link for Hp F2210 for Windows 7 (64-bits)
Download the driver according to your Windows 7 bits version and install it.
Your Printer will work fine.
2answers
Hpqthb08.exe and HPQDocViewer.exe error messages
****, since you have been having many issues, I guess that your windows is corrupted.
The best way to proced is to install a clean copy of Windows, install all of services packs and updates and then install the HP software and test the printer.
I know this is a lot of work, but it probably will solve this and many other problem that you are experiencing.
good luck!
Top HEWLETT-PACKARD Office Equipment & Supplies Experts
Daniel Blask
Daniel Blask
Obehiaghe Adoghe
Obehiaghe Adoghe
Are you a HEWLETT-PACKARD Office Equipment and Supply Expert? Answer questions, earn points and help others
