Question about Hotpoint Aquarius WMA42 Front Load Washer
F-01 my wahing mechine is not letting water go though it keeps flashing f-01 what does that mean
I went on to the hotpoint website which told me what was wrong
Posted on Sep 19, 2008
6ya staff
SOURCE:
Pump 14292 for power washer
Water should come out the tip even if the mechine is not running if the water is on. So there for now water is flowing through the punp at all witch mean you have a problem with a restriction of water flowing through the pump . What dose it do with the engine running dose the blow out valve open and water come out there . Dose the pump spin .Is there water in the pump oil .How often do you use the mechine and is it kepted in the cold over the winter with out winterizeing it Give more information mabey i can help you but it dosn't sound to good now
May 28, 2012 | Briggs & Stratton Garden
I have a LG direct drive wahing machine and its flashing IE cant find manual what does it mean please help!
An IE error code will appear if the washer has not filled with water in approximately 8 minutes. Check to make sure both hot and cold-water taps are open completely. After both valves have been opened, unplug the washer for 10 seconds and retry the wash cycle. There are filters on the inlet hose connections of the washing machine. If clogged, water will not flow through these filters into the washer. Disconnect the inlet hoses from the back of the washing machine, and clean the inlet filters gently but thoroughly. wm_inlet_filter_removal(1).jpg If this doesn't work then you will need to change the water inlet valve by removing the top panel.
Mar 15, 2011 | LG Washing Machines
Indesit wahing machine WIE 167 keeps filling with water and did flash H2O have replaced the switch mechinism inside but to no avail tube is not punctured or coroded - will not go onto wash cycle but will...
You need to clear out pressure chamber the part the at tube plugs into the chamber it will be clogged, stopping air going to pressure switch...This should cure..
Oct 07, 2009 | Washing Machines
Error Code "TEST"
Just had the same problem & found the following solution via the web :-
1. When tESt shows hold down both the ON/OFF Button & the START Button together & let the Test proceed holding the two buttons down for the entire test (Approx 3 Minutes ) .
Continue to hold the " buttons down until the word Done appears.
After which you should be able to proceed with the normal wash cycle
May 28, 2009 | Hotpoint Ultima WF860 Front Load Washer
Keep washing never stop.
either the heater is faulty or pcb corrupt.. have you any flashing lights as these are fault codes.
Feb 21, 2009 | Hotpoint Ultima WF860 Front Load Washer
Error code on electrolux
Haven't tried your solution but I'm keeping it in mind. I talked to a repairman and he suggested I remove the panel at the bottom of the dishwasher (left side). There I will see a red button which is the control board processor reset button.
This worked but if the problem reoccurs I will try your solution as it is easier than removing a panel.
Dec 28, 2008 | Dishwashers
Help with whirlpool awm 8103/1
Okay, ther manufacturer recommends unplugging the washer for at least 30 minutes to reset the computer. It could be you have a momentary glitch causing some problems. If you still have the same problem after leaving the washer unplugged, the following link explains the "FH" error code:
http://www.fixya.com/support/r615354-fh_error_code_whirlpool_duet_kenmore
If your clothes are stuck inside and you still cannot get them out because the door will not unlock, you will have to use the manual release to open the door. The next link explains how:
http://www.fixya.com/support/r622155-kenmore_elite_whirlpool_duet_door_jammed
I hope this helps you. If you require additional assistance, please let me know.
Aug 27, 2008 | Whirlpool GHW9300 Duet Washer
Kenmore Elite HE 5t
Low or no water supply, hot or cold side or water pressure switch not switching over to indicate fully filled though if this happens drain motor will continue to run continuously while f-20 flashes
Jan 15, 2008 | Kenmore Elite 45986 Front Load Washer
Hotpoint Aquarius WMA42 Front Load Washer Logo
143 people viewed this question
Top Hotpoint Washing Machines Experts
vince
Eric Taylor
James Hehling
James Hehling
Level 1 Expert
Are you a Hotpoint Washing Machine Expert? Answer questions, earn points and help others
