Euro-Pro Shark GI490 Iron Logo
Anonymous Posted on Sep 27, 2011
Just stop working. seems as if no electric power is reaching wherever it is suppose to. Iron is about 2 years old.
Anonymous
Level 3:
  • Euro-Pro Master 43,501 Answers
  • Posted on Sep 27, 2011
Anonymous
Euro-Pro Master
Level 3:
Answers
43501
Questions
0
Helped
10843907
Points
101584
Those types of problems are usually one of two things... the cord where is enters the iron, the wires are broken. Or the thermostat has gone bad...
The iron will need to be taken apart and the wiring checked witha meter to find the problem for sure...
heatman101
It is my first time using it, I brought it from USA and it is not working at all!!
follow this steps and fix it. God bless you
If the iron doesn't heat, make sure power is on to the outlet, check the electric cord and check the thermostat .
If the iron heats but steams improperly, inspect the soleplate and clean the vents (see below) and flush sediment out of the steam chamber (see below).
If the iron produces too much or too little heat, test the electrical cord . Also test and, if needed, adjust calibration of the thermostat
If the iron does not spray properly, inspect and clean the nozzle
If the iron leaks or spits, clean the steam vents, nozzle, and tank.
If the iron sticks to fabric, clean or repair the soleplate. If the iron stains fabric, clean the soleplate, clean the tank with a commercial cleaner, and use distilled or filtered water.
3helpful
2 year old iron lost power while ironing. Plugged it in to other working outlets. Light remains off.
It has defective parts, either the wire is open or the heating element also a defective plug cord.
It can be check by a continuity tester, if you have and knows how to use it.
If not, call or ask who has knowledge in appliance or electrical repair for assistance.
Thanks for asking.
Euro Pro Irons: Less than a year old stop heating up.
hello,
some time no part of our property go bad but what will need is to service them from there dysfunction
the problem of your iron could be from the element and the wire ,the element is the heat provider while the wire is the power supply from the electric
But the fact is that ,the problem of your iron is disconnection of element from the wire what you need to do fix it to unscrew your iron and trace the wire down to the element and see the disconnection am toking about and fix it back
thank you and thanks for using fixya.
Iron won't heat up, the 3 lights of yello green and red blinking
Here is a tip that will help you to troubleshoot your iron and figure out what is wrong with it.
Electric Iron not Heating Up or not Working Right
http://www.fixya.com/support/r5300202-electric_iron_not_heating_up_or_not
heatman101
Iron was leaking and now stopped working - 2 months old
Try using different water...
Here is a tip that will help you with that problem...
My Steam Iron is Leaking Water
http://www.fixya.com/support/r5301301-steam_iron_leaking_water
heatman101
1helpful
2answers
Iron just stopped working, no lights, no heat no iron Opened back panel to make sure no loose wires or damage inside. The inside still looks bran new and the wire cap connectors are intact. Iron may be 2-3...
check plug fuse, if ok, check continuity of the live, neutral and earth conductors for a break. if ok, element may be faulty. Any smell of carbon burning?
Oct 26, 2009 • Irons
1helpful
2answers
SHARK IRON WITH TANK.GREAT BUT SUDDENLY STOPPED.
these along with coffeemakers have a thermal fuse for safety the fuse looks like a cilinder with one flat side and the other side pointed with a wire protruding on both sides. it is located inline with the heating element under the cover "Appliance Parts" on the internet sells the part
Top Euro-Pro Irons Experts
NOEL
NOEL
ADMIN Andrew
ADMIN Andrew
Are you an Euro-Pro Iron Expert? Answer questions, earn points and help others
