When there is a noise it is important to know the source of the noise. In the case of a fridge the fault is usually a poor compressor motor assmebly mounting. Over a time the bushes and the mountings can wear out and result in noise when the compressor vibrates. Also when the motor runs , in many cases it can produce a sympathetic vibration as the grills, the rear fitting or plastic can make noise. finally a fault within the compressor can be related to this specially if you can place a hearing probe to know the emission of noise.
im sorry to tell you, but the sound is probobly normal.
fridges these days make some weird noises.
they started making noises when they changed the gas to R34a.
you may be able to get a noise ruduction kit for your model. they are not too fun to install
