AEG 24 in. Favorit 60820W Free-standing Dishwasher Logo
Anonymous Posted on Sep 26, 2011
I have an AEG 60820 Sensorlogic. It stops half way through the wash cycle and code 20 appears, what does this mean?
5 Related Answers
A
Anonymous
  • Posted on Nov 06, 2008
SOURCE: AEG Favorit 50730 Sensorlogic Dishwasher:
get a new dishwasher
Anonymous
  • Posted on Jun 06, 2009
SOURCE: Hello, we have the AEG 60820 Sensorlogic
Hi there
Found this site with the instruction booklet. PDF form so you might want to download and print out for future reference?
http://www.serviceforce.co.uk/pdfs/U22467.pdf
Anonymous
  • 174 Answers
  • Posted on Jul 19, 2010
SOURCE: I have a dishwasher that only works intermitently...
most fault codes are 10, 20,30.........90 not familar with c2. ther is a fault earky on in a prog where if the pressure switch does not retun to empty the prog stops and displays 10 or 30. the pipe leading from the front of the sump to the pressure switch can sag. tieing it up to stop the sag can cure this..
Anonymous
  • Posted on Oct 20, 2010
SOURCE: Our AEG Favorit Sensorlogic Turbodryis
i have the same problem, i have a machine that is 2005 model and it does not heat the water or dry in the end
Sam
  • 3247 Answers
  • Posted on Dec 29, 2010
SOURCE: aeg sensorlogic 50700 first showed c2 message; we
Error message C3 is most likely indicating the flood switch is triggered. This means water is leaking from under the sump. The C2 error is linked to drain problems which you cleared.
1helpful
AEG FAVORIT 35085 Vi dishwasher Beeps 5 times and stops
If your AEG FAVORIT 35085 Vi dishwasher beeps five times and stops halfway through a wash cycle, there could be a few potential causes for this issue. One possibility is that there is a problem with the water supply, such as a clogged or partially blocked inlet valve. Another potential issue could be related to the drainage system, such as a clogged filter or a malfunctioning drain pump. It's also worth checking if the dishwasher's spray arms are spinning freely and not obstructed by any debris. If the problem persists, it is recommended to consult the dishwasher's manual or contact AEG's customer support for further assistance. They can provide specific troubleshooting steps and guidance based on your dishwasher's model and any error codes that may be displayed.
Aeg electrolux dishwasher wont wash just keeps beeping
well there are several possibility's. What was the washer doing? Rinse or cleaning? If there is standing water in the tub, then the pump went out or is clogged.
Dec 04, 2012 • Dishwashers
6helpful
Aeg sensorlogic 50700 first showed c2 message; we drained & cleaned filters 3 times; worked half cycle and now showing error message c3?
1helpful
I have an AEG Lavamat L 16850. It has stopped showing an EFO error code for the second time (on the 20 minute cycle both times). The first time I removed the fluff filter which seemed to solve the...
We have this problem for nearly 2 years now. It always occured in a special program ("Kochwäsche/Buntwäsche 60°" what means coloureds/boiled 60°).
The AEG technician didn't find the problem. Since we avoided that program, the problem never occured again.
But now, close before 2-years-warranty-by-law I demanded them again to repair it. I will report.
2helpful
AEG Dishwasher 60820 Sensorlogic Delay timer stuck on 1Hr
This does sound like a problem with the "anti-flood" device that does detect water (leak / spill) at the base of the washer. This device is a protection device that consists of a polystirene float and a micro swithch. Once a water leak od spill is detected it automatically puts the washer in pump out mode. You need to determine if a leak exists that has caused the float to trigger the micro switch and clear the water / leak. This should put the washer back to normal.
However if the senslogic (pc board) has a program fault, the cost of this board = half the cost of a new washer ......
AEG lavamat 6955 sensorlogic, was showing F2,nowF3
Waited half hour; on start up F3 had cleared..pump overheat? Suspect sticky pump bearing..new pump.
3helpful
2answers
Hello, we have the AEG 60820 Sensorlogic dishwasher but no instruction manual. Please could you tell us when we should use the ''Automatic'' button and the ''Energy saving'' button? And what the advantages...
With the auto setting, the machine detrmines the time based on the load. With energy saving, you force the machine to use the least amount of water and heat, usually best for cups and glasses.
1helpful
Top AEG Dishwashers Experts
Paul Carew
Dominic Harborne
Level 1 Expert
Kolbrun...
Are you an AEG Dishwasher Expert? Answer questions, earn points and help others
