Most of the cases, power supply goes bad, open check the input fuse, if its open check primary section of the power section, replace defective components.. if power supply good replace formatter..
Hi, it sounds like your printer cannot translate the the graphics being sent from your computer. It may be that one of your printer settings is not set correctly. Or, it may be as simple a solution as updating your driver for your printer. Try here for a driver for Laserjet P2055D:
If this is not your model, search for your specific model on this HP website. Note there are also firmware upgrades for the P2055D printer. Cheers, Steve
Power off printer, wait at least 30 seconds and power it on. Make sure that the printer is not on a surge protector. It should be plugged directly into a wall outlet. If this doesn't help, you are probably looking at a replacement laser/scanner assembly.
