The
F35 error code indicates a problem with the analog pressure sensor, air
hose or air trap. If the hose and trap are good you will need to
replace the pressure sensor
The "Sud" error code indicates too
much or the wrong kind of laundry soap was used. Be sure to use only HE
(high efficiency) detergent on this model of washer.
Please see the links provided below for access instructions & other troubleshooting tips covering the error codes displayed:
- Link 1
- Link 2
Hope this helps (remember to rate this free answer and leave some testimonial).
Hello & Welcome to FixYa
F35 error means that there is some sort of issue
with the steamer electronic board and analog pressure sensor has gone bad.
Check that the hose is firmly attached with the washer and is not blocked. You
can also check the water level pressure switch operation. Please get back to me
if you have any other questions.
Kevin
