SOURCE: Draining water from inside through center.
The tub seal kit is $85 USD, You will also need a drive bell kit$23 USD, you should replace the upper bearing $?, for a complete rebuilt I would also replace the brake pads all three, and the belt, maybe the pump if it doesnt come off easily. Plus what you break taking it apart, so we are looking @ least $150.
Yes you can do it yourself, you dont need the tub wrench if you can borrow a deep socket, its the drive bell seal tool you really need.
Please let me know if you have additional questions. the serial number will tell you the age first two digits are year next two are month, starts with and R, built in Ripon WI.
SOURCE: At start of spin cycle water splashes over top and runs down.
Hi, just fixed the daughters speed queen, same problem. The three brake shoes were worn allowing the tub to spin with the agitator.
replaced the shoes, washer fine. At first I thought it was the top ring. spent 30 dollars for nothing.
good luck
SOURCE: Replace Water Pump on Speed Queen Washer
did you look at the front panel if you tip the machine to the back and look at the bottom of the panel you will see 2 hex head screws remove them and lift the panel out and slide it down some machines others you have to remove the top
SOURCE: Speed Queen top loader leaks from top of tub at large load spin c
make sure unit is level possibly lower front legs down so front sits higher,,, and also when u put or load in push the tub back so when the water enters it all enters into the tub sometimes the water will splash on the tube and cause a problem u are discribing hope this help
