the btu rating will be on the same plate as the model number
if there is no btu rating but a kw rating then there are conversion tables to work it out
for example a 2kw unit is close to 9000 btu and a 8kw unit is around 32000btu
if you have the model number of the furnace, then you have the btu input of the furnace. The model number usually starts with letters, then the three numbers following the letters are usually the btu input of the furnace.
For instance if it said 075 then it would have an input rating of 75,000 btu/hr or if it said 125 then it would have an input rating of 125,000 btu/hr.
mcdevito75 Here, Idid a fast online search, couldn"t find BTU rating but did find Bryant's contact info, 800-428-4326 give them a call with the make and model numbers.
The Tonnage appears to be 2 1/2 ton,
024=24,000 BTU=2ton
030=30,000 BTU=2 1/2ton
036=36,000 BTU= 3ton
I dont think you have the correct Model Number, Look
on the outdoor unit, the model number might start with a 38. Hint Carrier and Bryant Products are the Same, just different nametag
With air conditioning, you want to go by BTU ratings, not horsepower. If you can get number straight off the compressor, an a/c supplies could get you an approximate BTU rating.
In most cases, the "Tonage" is in the model number.
Remember, 1 ton of cooling is 12K BTU's per hour.
Hope this helps.
You will have to contact Sears for this information. Give their service dept. a call and give them your model number which should be located on the inside of the door. They will be able to give you the BTU rating.
that is a three ton unit and most likely a 10 seer rated seer rating are posted 6 months in cool and 6 months in heat to get the number on the unit if you are more interested in heating rating of heat pumps the aher or annual heating efficiency rating is of the most importance in this category the unit posted very well
