Lexmark X4270 All-In-One InkJet Printer Logo
Anonymous Posted on Sep 24, 2011
I cannot receive faxes on my lexmark X4270. It will ring but nothing come through
  • Official Brand Answer 3,344 Answers
  • Posted on Oct 03, 2011
Anonymous
Level 0:
Answers
3344
Questions
0
Helped
922748
Points
5508
Please go through the following checklists:
  • Make sure the that the fax line is working. To check, insert a telephone device straight to the fax line. You should get a dial tone.
  • Make sure the telephone cord from the phone jack in the wall is plugged into the Line port on the back of your Lexmark printer.
  • Assign the correct fax number on the printer.
  • If you have an answering machine connected to the same line as the fax, set the answering machine to answer incoming calls before the printer does. Increase the number of rings by a factor of 3 over the answering machine. For example, if the answering machine is set to pick up on 4 rings, set the printer to pick up on 7 rings.
  • If you have a voicemail feature in the same line as the fax, you may subscribe from your phone service provider for a distinctive ring pattern feature. You can program your printer to have a distinctive ring pattern and phone number for incoming faxes.
If these don't help, please contact Lexmark Technical Support Center for additional assistance.
How do i change my fax settings?I want to change number of rings before the fax picks up.
Here's an article on How to Set the Number of Rings on the Lexmark X4250/X4270/F4270. Just click on this link: http://bit.ly/c0mhg1. Just follow the instructions. Hope this helps. Thanks.
I have a (time Warner) package deal that consist of cable vision internet telephone & voicemail. I am trying to get the fax machine to work along with these items. My voice mail picks up on the 5th...
Here's the link to download the Lexmark X4270 User's Guide: http://bit.ly/cNbUKo. If you prefer to have the printer pick up faxes automatically, I suggest you configure the printer to pickup after the 2nd or 3rd ring before your voicemail picks it up. On the User's Guide, go to Faxing, Receiving a Fax for the instructions. For more info about the printer, go through the User's Guide. Hope this helps.
How do I set up my fax to my Lezmark X4270
Here's the link to download the Lexmark X4270 User's Guide. http://www.lexmark.com/publications/pdfs/2007/4200/ug/en/frameset.html. Scroll to Setting up the All-in-One for instructions on how setup the printer for faxing. Hope this helps.
Fax machine will not let me send fax out or come in. x4270
make sure the phone wire which you insert in fax machine getting proper dial tone and getting out going calling facility and line is working.go to menu option and choose the option fax and set the parameter like auto receive or manual set the ring auto answer mode after certain ring. If it is in auto receiving mode it will receive the fax after the ring which you set.
Hope this helps. Please rate my response.
Thanks.
Have a good day.
Lexmark x4270 will send fax but won't receive
Hello sir; The better solution is replace a phone cable.
I just bought a x4270 lexmark.i do not see in the maual set up for smart ring,another term is short ring and ido have a answering machine set up aswell.im wondering if i can even use this unit.any answers?
Yes, you can.
You have to connect the answering machine to the X4270 like this
http://www.lexmark.com/publications/pdfs/2007/4200/ug/en/basics.html#wp633882
and set it to answer before the X4270 does. Say, 4 rings for the answering machine and 5 for the X4270.
The X4270 will monitor the few first seconds of the call anyway, and if it detects the whistle of an incoming fax, it will disconnect the answering machine and receive the fax.
With most answering machines, disconnecting while the greeting message is still playing will not be considered a call.
1helpful
2answers
I need the manual of lexmark fax x4270
Go to the Lexmark web site. You will be able to download a manual in Adobe format.
UNALBE TO RECEIVE FAXES
Problem Receiving--
Make sure ur answering Mech rings are set more than the fax mech...i.e (if ur answering mech is set to 3 then fax mech should be set to 4)....
If u r using DRPD(distingtive ring pattern i.e If u have one line and two numbers.....) then set double ring for fax and single for Phone or answering mech....or vice versa...
Cannot receive a fax
I had the same problem when i first install my fax machine and at that time I only had the black ink cartridge in the fax machine one's I installed the color ink cartridge, my fax machine started working.
Lexmark X4270
Have you told your pc the fax equipment you want to use, and does it appear in the device managers list?
Top Lexmark Office Equipment & Supplies Experts
Grand Canyon Tech
Grand Canyon Tech
k24674
Are you a Lexmark Office Equipment and Supply Expert? Answer questions, earn points and help others
