? 6:57
https://www.youtube.com/watch?v=2nDgSSFBt3I
Jun 28, 2012 - Uploaded by plumberparts
How to get a water tight seal and a great flush! ... tell you how a to remove and install a push button flush unit on your toilet. ...Top comments.
? 5:36
https://www.youtube.com/watch?v=T-WPaiLsMDU
Mar 14, 2014 - Uploaded by Flush King
James brings an old lever flush toilet up to date by showing you how to install a modern and water saving ...
if your flapper is held open and the toilet rises to the rim and does not flush then you need a closet auger and clean out the toilet as it has debris restricting the flush
Sorry to read about your problem, I hope this helps you out.
i dont think you have toilet issue,
Try this. take a large bucket, like a paint or home depot orange bucket. fill 1/2 way... put some toilet paper in the toilet. Then pour the water in fast, and see how it flushes. it it does a easy flush then your drain is ok. if its slow, you have a drain issue and not the toilet.
if that the case, then goto the toilet, and clean out all of the little holes, that are around the unit.. where you see the water come out. they can be clogged up. a small type wire like a clothes hanger.
I tried to help you. Please help me and Rate/Vote on my response. We take the time to answer your question. take the time to rate us.Thanks and good luck
use a two gallon buck to flush your toilet - you pour the two gallons directly into the toilet bowl if it flushes fine you need to replace the flush valve, as it is not letting enough water through to properly flush the commode. either rebuild the flush system in the tank or install a fluid master and have a good nights sleep knowing that in the morning you will not leave a suprise for someone else in the family.
I am not a toto expert but i think i understand the gravity control toilet concept.A gravity flush tank type toilet flushes do to the force of water traveling from the tank to the bowl in a small passageway and forces the water in the bowl towards the integral trap in the toilet.In other words the water isnt dumping quick enough or the passageway is restricted.,My guess is the flush valve isnt dumping all at once.
