For as long as I can remember, the phone always displays the message in the subject line on the screen while idle (if a call comes in it changes to display who's calling, etc.). Power cycling the phone doesn't seem to help at all.
Thanks.
Power cycling is not supposed to clear the incoming call log.
I will give you the book description of how to use the Navigator key on a 76xx phone. It may or may not work.
You can program a call log button, or use the Navigator to display, call, or erase the incoming call log. To display, press the call log button or left arrow on the navigator button twice.
It will show the last call. While that display is viewable, press the TRANSFER button to delete it, or lift the handset or press SP-PHONE to call it..
Your up and down arrow keys will step between the calls if you have more than one.
To program a button for call log, press the PROG softkey, a button, dial 54, and STORE.
These are the instructions for your personal call log. There are also instructions for Incoming Call Group (ICD) call logs.
These and other instructions are outlined in the TDA Operating manual.
Your dealer/installer should be able to get you a copy if you don't have one.
Carl
Haha, wow, I guess I just understood what the message meant! That must have sounded like a really novice user (which I am with business-y phones I guess!).
Thanks for the help.
handset display is no longer showing anything at all. It is always blank even for incoming calls, when I hit 'menu', etc..
