You want to try and see if there is a driver update for the ethernet controller. Go to: START> RIGHT CLICK "MY COMPUTER"> then PROPERTIES> DEVICE MANAGER> NETWORKING> ETHERNET PORT. You can roll-back the driver or you can try to update the ethernet driver using Windows Update Program. Make sure the driver is located in the device manager system and windows recognizes it. Your Ethernet Controller is a discontinued product. If you can't seem to get the ethernet controller to work and don't have the Floppy Disk Driver for it, then I suggest replacing it with a new stand alone ethernet controller that uses PCI or PCI-E ports. You can find some at Best Buy and Staples. They are easy to install and they don't use your motherboard memory and are not integrated on motherboard. I hope you find something that works and you can get back online again.
Does your motherboard have a built-in Ethernet controller?
Are the correct device-drivers loaded, so that Windows can use that controller?
Do you have an add-in Ethernet adapter connected to a PCI slot on the motherboard?
first check for all the drivers in the device manager....
if every thing is perfect in driver side, then check if the ethernet/ lan is enabled....
then check is the light in the ethernet adapter is lit, when you plug any ethenet cable in it...
still if it is not working, then finally try to update the latest driver for the ethernet controller....
if nothing works, then buy an pci ethernet card and use it.....
you can also buy external cards like usb to ethernet converter...
even belkin manufactures usb to ethernet controller....
If you have no internet because the ethernet controller was not installed, you will need to download the ethernet drivers from another computer.
To do this, you will need either the motherboard model or the ethernet controller model. Search google for your motherboard model, and then on the drivers page, find "LAN drivers". Download the drivers, save them to a usb and transfer and install them to your pc.
you nedd to go to a website and download an updated ethernet controller driver are useless because you can't even access the internet without the ethernet controller, unless you have a second PC already hooked up to work with the internet, then make a copy of the ethernet driver, and then copy it onto the original PC to get it acces the intenet. Most people may have to go to a computer repair store and ask if they can buy the ethernet controller driver for their OS and PC on a CD or flashdrive, or instead, but an external Ehternet controller device and connect it to your PC via USB.
Hi, You need to re-install your Ethernet driver.If you have Driver CD with you then first uninstall the Ethernet driver from device manager and install the Ethernet driver from you driver CD. If you don't have driver CD with you then You can download ethernet driver by Clicking here.
use driver updating software ie driver magician. it scans ur outdated drivers and automatically downloads drivers that r compatible for your computer.............
